730 thrust washers
JDGMC
01-21-2006 19:37:17
I've got the flywheel and timing cover off my 730D. I'm planning to replace both the outer and inner crankshaft fiber thrust washers. Can anyone tell me if there is a way to get the left main bearing cap off to get to the inner thrust washer without having to remove the gears?
Thanks for any repies,
JDGMC
Kevin L.
01-21-2006 22:07:45
 Re: 730 thrust washers in reply to JDGMC, 01-21-2006 19:37:17
if I've read the question correctly...
Nope....
and not keep the crankshaft in one whole reuseable piece...
Kevin L.
01-21-2006 22:14:13
 Re: 730 thrust washers in reply to Kevin L., 01-21-2006 22:07:45
can the endplay not be set or are they broke. would think the flywheel would been more of the problem or not pushing the crankshaft to the left when setting the endplay.
Kevin L.
01-22-2006 19:32:26
 Re: 730 thrust washers in reply to Kevin L., 01-21-2006 22:14:13
there have been other post about using a (i think) 3" diameter pipe, cut the length of the flywheel thickness to see how close you are in the endplay with out having to reinstall the flywheel but does require putting the side cover back on. if it was me, I'd even pull the pony motor or electric starter to verify the inner thrust washer at $50, I would not want the inner one to be out of the slot and it get broke. Dont think the crankshaft can go far enough to the right to let the washer out of the slot without removing the left main bearing. Also verify with your finger in the center oil drain hole for extra parts or pieces which may force you in to the top of the big motor..
Mike M
01-23-2006 09:40:49
 Re: 730 thrust washers in reply to Kevin L., 01-22-2006 19:32:26
That 3" pipe is used on the 70 and early 720 tractors that have shims behind a cover plate to adjust the end play. The later 720 and 730 you just slide the fylwheel on farther to take up the play. These later ones are also the ones with the hard to get at inner thrust washer. The early one you can get to both thrust washers without too much trouble.
JDGMC
01-22-2006 06:49:56
The outer washer only had a couple of small pieces left of it. I had received advice to also relace the inner washer too. I think that is good advice but didn't realize just how much work that would be. There was originally about .125" endplay - lots! This pointed me in the direction to check into the thrust washers. It was actually quite easy to get the flywheel off but removing all those gears and whole drive mechanism above was more than I was originally barginning for. The crackshaft still has lots of lateral movement so I still do think the inner washer is shot.
JDGMC
Mike M
01-22-2006 17:52:27
 Re: 730 thrust washers in reply to JDGMC, 01-22-2006 06:49:56
If you still have the flywheel off you will have alot of movement of that crank. Do you have electric start ? If so once you take off the top cover you should be able to see if that washer is in there or not. If you have a pony motor I doubt it's worth the time to look first.
Once you get that washer back in there (if you even mess with it)block the crank over to the left. I place some blocks and a long board over in the clutch against the end of the crank and the tire then bring the long board up tie it against the front frame rail to hold it.
This way the washer will stay put while putting on the fylwheel.
