Help me identify my tractor
Ron Lubke
01-21-2006 19:36:11
I just bought what I belive is a JD 420 [slant steer]. It does not have a serial plate and I'm trying dertermine if it is a utility or standard and what the serial number is.
JD man in SD
01-22-2006 04:59:51
 Re: Help me identify my tractor in reply to Ron Lubke, 01-21-2006 19:36:11
GO to JD dealer & look in pasts book there are pict. in front of book that show diff models deere can get you the serial plate you need engine # it is stamped in fount side of block below gen also trans # is on top front,left of trans case under hyd lines the dealer has to go thru block man to get the new tag
CPeter
01-22-2006 06:11:49
 Re: Help me identify my tractor in reply to JD man in SD, 01-22-2006 04:59:51
A utility has the final drives turned to the rear. A standard has them pointed straight down and a 2 row utility has them on the inside.
CPeter
