How to bleed JD 4010?
RFox
01-21-2006 16:57:39
Ok, moving big bales around today, and my 3 pt lift started chattering, pump was louder than normal, and when at a low idle steering and brakes act like they're starving for oil. Checked the oil, it was full, but VERY bubbly - like too much air(?). Any idea how best to bleed the system? Normally has very strong hydraulics. Any other ideas? In case its not just air? Would too much air in system cause this?
Thanks, Randy.
donmyeil
01-21-2006 18:37:58
 Re: How to bleed JD 4010? in reply to RFox, 01-21-2006 16:57:39
There is no way to bleed the air from the system. It takes care of itself,asuming you have Deere hygard oil or equal. I would change the trany filter. Then I would put a pressure gauge on it if that doesnt help. could be a problem with the pump. Also doing a lot of loader work with the clutch pedal down ,will cause the pump to run out of oil and do what you describe. Don
