Gas line replacement mtl.
Elk Hunter
01-20-2006 12:51:11
What would be the best route to go to replace a gas line? I'm not too concerned about keeping to original, just want it to hold up.I saw an unstyled a with soft copper. How about a piece of brake line, the only trouble is the ends. Original from dealer is 60 bucks. - Tom
CalJim
01-20-2006 21:17:15
 Re: Gas line replacement mtl. in reply to Elk Hunter, 01-20-2006 12:51:11
Don't use copper its too soft and will
crack with the vibration. CalJim
41JDb
01-20-2006 19:51:06
I also used a break line from the auto parts store (it came with two male ens so I got two male to male adapters at the hardware and I was all set! Also if you need to make it shorter you will need two male to males with the little couplings from the auto store.
Elk Hunter
01-21-2006 04:23:16
 Re: Gas line replacement mtl. in reply to 41JDb, 01-20-2006 19:51:06
Both you and Jim said about using couplers you just tighten down, are you using compression fittings? Roberts carb said his fittings needed swaged on???? Also his are 5 bucks a piece, seems a little salty?? -Tom
Jim@concordfarms.
01-21-2006 07:34:38
 Re: Gas line replacement mtl. in reply to Elk Hunter, 01-21-2006 04:23:16
I hope I didn't lead anyone astray here. The fittings I used from Robert's were: R2150R nut and R2069R Gland (ferrule). I used these fittings because they correctly match the flare and threads one the carburetor and the 3 way fuel valve. I just assume I did it right, because it doesn't leak. I don't see any way to swage it, and don't know what kind of a tool would do it. As to the cost, 5 or 6 dollars per fitting may be a little steep, but it's still less than what Mother Deere wants. I've found Robert's to be a good place to get parts. Their prices on magneto parts are especially good compared to Deere. Jim.
41JDb
01-21-2006 06:29:06
Yes they are little compression fittings from the auto parts store only like 2 or 3 bucks.
Elk Hunter
01-21-2006 07:47:22
 Re: Gas line replacement mtl. in reply to 41JDb, 01-21-2006 06:29:06
Thanks all for the tips.... Got er done already. On to the next repair! -Tom
Jim@concordfarms.
01-20-2006 13:48:08
I recently replaced one on an A. I used a piece of 5/16 steel brake line from NAPA and used ferrules and nuts from Robert's Carburetor. Just cut off the double flared ends and slip the nut and ferrule on and tighten it down. About $22.00 total. Jim.
