G CLUTCH PULLEY REMOVAL
HAL
01-20-2006 09:24:16
I am tearing down a 51 G that has sat for quite sometime outside, I tried to remove the drive disc last night with no luck but havent given up, i also tried to remove the clutch fork but it seems to be hanging on something, I am guessing that the clutch was left engaged when it was left as i cant turn the crank or anything, this is my first dealing with a stuck clutch and dont want to break anything, once I get the clutch driver off is everything going to come free or is there something else I will need to do to loosen things up? Thanks Hal
DW
01-20-2006 20:24:46
 Re: G CLUTCH PULLEY REMOVAL in reply to HAL, 01-20-2006 09:24:16
Penne-lube penetrating oil works twice as good as pb blaster in my opinion. What ever you prefer...along with patience, and heat. My $.02
Magoo1
01-20-2006 13:17:56
Just did the same thing with a 60 that was burned and sat outside for 40 years. Use the square head nuts to pull the clutch driver. I have found it helpful to pressure wash the area and then use a hand held propane tourch (MAPP gas is best)to burn away small flakes of rust. And keep the blaster going. Read the book and take your time is the best way. My $.02
Jak
01-20-2006 10:52:37
You may have to use a puller on the drive disc and don't be afraid to use a red wrench(torch),the ones I have dealt with had to be heated in order to remove them.Main thing is to be patient.Good luck
BushogPapa
01-20-2006 09:53:24
Above all..Don't break the Clutch Drum...!
NEVER FORCE the castellated nuts on the 3 Clutch Bolts..you WILL Break the Clutch Drum..!! Soak, heat or grind the nuts of but don't force them very much.. If you think the clutch is engaged, get the 3 castellated nuts off and soak everything until it will release... try to get the solvent into the Backside of the pulley, to soak the pivots and clutch-dogs..they could be stuck.. You should be able to get the clutch driver out..even if the clutch sleeve is stuck.. Seems that the clutch fork should come out, too..once the plates and driver are removed..then the whole clutchdrum will slide off..then you can soak the entire assembly to free it up.
Ron..
HAL
01-20-2006 10:28:41
 Re: G CLUTCH PULLEY REMOVAL in reply to BushogPapa, 01-20-2006 09:53:24
I got the castle nuts off ok, 2 of the 3 bolts seem loose one of them seems to be pretty snug I have been soaking them with PB blaster since last night
