JD 112
Al Cook
01-20-2006 07:02:08
Hello all, I am in the need for a short block or complete engine for a JD 112 lawn tractor. It is as follows. HH100 Tecumseh, model HH100 1150939, serial number 8192 08655. Need it for an early 60s lawn tractor. Need price and shipping info. I am in Maine.
Thank you
buckeye al
01-23-2006 10:03:29
 Re: JD 112 in reply to Al Cook, 01-20-2006 07:02:08
Was maybe 6 years ago I went to my local small engine dealer (not JD) and asked them for new camshaft bearings for my HH 100.
Blank stare.
You know, the steel backed bearings that are pressed into the block and the cover that the camshaft rolls in.
Blanks stare. You can't get them unless you go for a short block.
Your kidding I say.
Nope. Never heard of anybody wearing those out. They usually run 'em out of oil first & throw a rod long before those wear out.
I had already cut the old bearings out (small burr in a die grinder) so I was screwed.
SOLUTION.... Since my cam was worn some though not nearly as much as the bushings, I ordered a pair of .75" ODx.562"ID caged needled roller bearings & pressed those into my block and cover. Then turned the cam down to 9/16" in a lathe. The cam is a bit soft & is starting to rattle again but it mowed about 2 hours a week for 4 years in Ohio to get there. It now gets little use but it still runs.
I really wanted a 3/4ODX5/8ID caged needled roller but couldn't find one. Then I'd have still cut the cam down but I'd have put a bearing bushing on it putting it back up to 5/8 with a real hard surface that would wear a LONG time! At the time, there were none to be found. Might still be that way.
If I had a parts engine, I'd have tried new steel backed bushings & a build up job on the cam but I didn't want to weld & maybe warp/ruin my only cam so that's why I went the way I did.
Al Cook
01-23-2006 11:09:38
 Re: JD 112 in reply to buckeye al, 01-23-2006 10:03:29
Buckeyeal, my problem is this.... Cam gear is broken. Engine had some trash in it and cam gear broke off the shaft, so I am still looking. Thanks for the info.
Al
Al Cook
01-23-2006 04:55:25
BuckeyeAl, Having trouble finding replacement parts to rebuild the engine. Can not locate a cam gear. Have found all others. Can you help?
Al
buckeye al
01-20-2006 14:09:27
The HH 100 was discontinued several years ago. Tecumseh still markets the HM 100 which basically is the same engine but with an iron liner in an aluminum block. They'll bolt right in where the HH 100 was.
Northern tool & equipment (among others) will ship one right to your door step.
I have 4 112's. Two with the HH100 and two with Kohlers. The HH 100 is quite rebuildable as long as it hasn't thrown a rod out the side! BTDT.
Good luck.
G/MAN
01-20-2006 10:20:49
I've got an very nice and original '67 112H that has a solid and good-running engine in it, in addition to the factory hydraulics. As far as I know, all the engine needs is a little carburetor work, as it doesn't want to idle without the choke on a little - probably junk in the idle circuit. It could also use a little work on the Variator, as it's a little noisy. However, I wouldn't consider selling just the engine, and I have a pretty good idea of what these things are "worth", so I don't know if you'd be interested in the whole thing or not. It also has a good but not correct deck on it, and it mows like a dream. If you'd be interested in the whole thing, email me at [email protected]. Also, there's a site called Weekend Freedom Machines that's all about JD lawn equipment, so you might check there and post a want ad.
buickanddeere
01-20-2006 07:43:48
www.smallenginewarehouse.com
Al Cook
01-20-2006 08:06:14
 Re: JD 112 in reply to buickanddeere, 01-20-2006 07:43:48
Thanks buickanddeere, the engine I am looking for is no longer available through them. Will keep trying.
Al
