Front Wheels on 1020?
Ten-Twenty
01-20-2006 04:11:55
My 1020 has JD1299 front wheels (4.5x16) with 6.50x16 tires (not a lot of room between the tire and the knee). I know this is not a "correct" application, but was wondering if it was common. It is my understanding that this was the set up since new. The tractor had a loader when new. The JD1299 wheel has a 2.25" offset and the "correct" application wheels have a 1.12". So, what front wheels are on your 1020?
Leon J
01-20-2006 09:47:27
 Re: Front Wheels on 1020? in reply to Ten-Twenty, 01-20-2006 04:11:55
I can"t help much on your problem, but I faced a similar problem yesterday. I have a 2240 that I just yesterday mounted 7.50 16 front tires (3 rib) on. When I went to put on the lug bolts, I noticed that it was rubbing on the ankle. So, I turned the rims over, thinking I had solved my problem....This morning a friend says this is hard on the front end. I don"t know....Maybe I"ll have to go to a 6.00 16 tire.
jdemaris
01-20-2006 06:28:26
 Re: Came with 15s and 16s in reply to Ten-Twenty, 01-20-2006 04:11:55
1020 was availble with three different front wheel options. 6.50 X 16" (JD30309), 7.50 X 15" (JD1091), and 11L X 15" (JD1102). I've got a 300 (industrial version of the 1020). Mine has 6.50 X 16" on front.
Ten-Twenty
01-20-2006 06:50:39
 Re: Came with 15s and 16s in reply to jdemaris, 01-20-2006 06:28:26
jdemaris,
The standard wheel for the 6.00x16 tire was the JD3002 (4x16). The JD1291 (4.5x16) was available for the 6.50x16 tire. The JD3039 (5.5x16) was available for the 7.50x16 tire. All of the wheels above had a 1.12" offset and the last three were heavier gauge steel. My question is really about the use of the (also heavier) JD1299 which had a 2.25" offset. I assume they were used on my tractor to provide more heft because of the loader. I was just wondering if anyone else out there had JD1299's on the front of a 1020.
jdemaris
01-20-2006 06:59:50
 Re: Came with 15s and 16s in reply to Ten-Twenty, 01-20-2006 06:50:39
I'm not sure what you mean by "standard." We sold 830s,1020s and 300s when they were new. When we ordered them from Deere Co., we filled in the blanks as to what options we wanted in each tractor. I don't recall anything in the paperwork about a "standard" package from Deere. It usually did not work like ordering cars though. When we placed an order, Deere didn't proceed to build a tractor. They would search inventory around the country and tell us what dealer was the closest to us with what we wanted. Many new tractors were swapped dealer-to-dealer. Same with log skidders and crawlers. In regard to front tractors with loaders - many of our customers used pickup-truck front tires, 8 ply or more, and we even had a few that bought 12 ply airplane tires. This applied to the 15 and 16 inch tires.
Ten-Twenty
01-20-2006 07:07:43
 Re: Came with 15s and 16s in reply to jdemaris, 01-20-2006 06:59:50
jdemaris,
Yes, "standard" was a poor choice of words. I guess I was trying to say that the 6.00x16 tire probably would have been the most common application on the 1020 and that would have called for a 4x16 rim (JD3002). Again, the mystery for me is the apparent mis-
application of the JD1299 rims on my tractor. Probably a mystery I will never solve.
