H speed control rod
J.P.
01-19-2006 17:22:33
The speed control rod (part # H282R) is was missing from our H as well as from both of our parts tractors. Can someone please help with a measurment of the length of this rod?
P Browning
01-20-2006 09:21:09
 Re: H speed control rod in reply to J.P., 01-19-2006 17:22:33
H282R Description:
Stock is 1/4 inch diameter threadable (not hardened) iron rod.
Length from threaded end to the center of the bend is 7-7/8 inches
Threads are 1/4-20, and run 1-1/4 inches up the rod
Length from two-hole end to center of bend is 1-3/8 inches
The two holes are 3/32 inch in diameter and approx. 19/32 inch apart, centered in the "straight" part of the two-hole section (shorter part after the bend.) (PatB)
J.P.
01-20-2006 09:44:29
 Re: H speed control rod in reply to P Browning, 01-20-2006 09:21:09
Thanks. Exactly what we needed. We'll have a new one by evening.
Billy C.
01-20-2006 05:22:13
I don't have the info here at home, but will be going to where I'm working on my"H" later today and will measure. If Pat Browning or someone else hasn't posted this by tonight I will give the length to you.
