4430 vs. 4440
dph
01-19-2006 10:25:06
What are your opinions on the differences between these two tractors. Our local dealer told us the differences were the lack of a hyd seat, and the 4020 motor, being used in the 4430. He said the rear end, if worked on, is usually updated to be the same as a 4440. Are the 4440s worth the extra $?
nw_bearcat
01-20-2006 19:33:29
 Re: 4430 vs. 4440 in reply to dph, 01-19-2006 10:25:06
We have one of each, the 4430 was supposedly "updated" with 4440 rear end update, but when comparing the two, the '40 housings and axles are larger. The '40 is just a slightly heavier tractor all the way around. we pull a 13' offset disk once in a while for food plots or working in ruts, and you can feel the difference between the tractors both in hp, and traction, even though both are weighted about the same and with similar rubber.
J. Schwiebert
01-19-2006 18:28:21
We have one of each. The main problem on the 4440 is it will nickel and dime you to death. It has half the hours of the 4430 and is broke down twice as much, yea I know most will tell you the other way. Biggest nickel and dime item: Air conditioning. We have had parts on it(airconditioning) fail under Deere's warrenty. Both are 2 wheel drive and both get from 100-140 hours each per year. I think we would like to try a red one.
G/MAN
01-20-2006 07:25:21
 Re: 4430 vs. 4440 in reply to J. Schwiebert, 01-19-2006 18:28:21
It's not the parts or the tractor, it's the people doing the work. Deere has contacted dealership about how many compressors come back in under parts warranty. They're usually full of junk and destroyed because the system wasn't properly flushed. If the job is done correctly the first time, a converted SGB A/C system should work correctly for years. Of course you also have to convince the customer that it's worth the time and money to do the job right. Replacing a piece here and a piece there usually doesn't do it.
timbo
01-20-2006 07:39:28
 Re: 4430 vs. 4440 in reply to G/MAN, 01-20-2006 07:25:21
G/MAN is right! Most farmers only want to "patch" things and you just can't do that! But they know how much they can spend, but it usually costs double or triple the amount down the road if not done right the first time.
Greg H. WV
01-19-2006 13:34:47
All I know is a good 4440 will bring between 5-10 thousand more in resale, in our neck of the woods, and the 4440 that is on my inlaws farm has been farming hard year in and year out with the pump turned up making 170 horse. Good strong tractor. Regardless of the model you choose it will probobly be hard to find one of these models that haven't been worked to death, because they were so strong, and folks primarily used them as a molboard/shank plowing, and discing tractor. Check your transmission linkages on the 30 series to ensure it stays in C range if its a quad shift tractor. Nothing like pulling a big mower conditioner over a steep grade at 7 miles an hour to have the puppy pop out of gear. Yeeha. Good luck with your tractor hunting, if it were me and i wanted that size tractor, I'd go with the newest series I could afford;less hours, and wear ect.. I like the looks of the 50 series with the lights up front. Later Greg H.
G/MAN
01-19-2006 10:35:13
4440s are bigger, stronger and more robust. Deere called them the new Iron Horses, with "more horses and more iron". They also have nicer and quieter cabs, in addition to the Hydra-Cushioned seat. As for the "4020 motor" being used in the 4430, that's pretty much bull, as the 6404T engine used in the 4430 is considerably different than the 6404 used in the 4020 - different head, different fuel-system, the 4430 obviously has a turbocharger and on and on. The two engines share the same bore, stroke and displacement, but that's pretty much where the similarity ends. That said, the 466 in the 4440 is bigger, stronger and produces more lugging power. The 4440 was also strengthened and beefed-up in several other areas of the powertrain. In my opinion, the 4440 is as much tractor as a 4630, and is better all-around than a 4430 in every way. So yes, I'd say the extra cost is well justified.
8e3k0
01-19-2006 11:33:08
 Re: 4430 vs. 4440 in reply to G/MAN, 01-19-2006 10:35:13
That extra torque that the 466s have is an advantage at the lower rpms that is missing with the 404s with near/ equivalent horsepower ratings. The 4440s are one tough tractor with a superior reputation in holding a high resale value at 24 to 28 years old!
G/MAN
01-19-2006 13:18:32
 Re: 4430 vs. 4440 in reply to 8e3k0, 01-19-2006 11:33:08
The extra torque down low with a 466 is an advantage with a 4440, but it doesn't seem like there should be such a big difference. The 404 has the same stroke after all, although a smaller bore. I've heard that having the 4430 pumps recalibrated to 4440 pump specs makes a world of difference in how a 4430 will pull down low.
