4630/4640 Fuel Pump
Shane S
01-19-2006 08:40:02
Hey guys,
I have a 4640 Bosch fuel pump to put on my 4630 engine. It looks pretty much the same as my original pump (my original pump was trash), except for the hydraulic aneroid (versus the original manual aneroid).
Anyway, question is, would it be safe to just install this pump or should I have the settings checked and have it put on a stand. Reason I ask is because my pump guy is gone for a week and I really want to get this thing on and running. How much difference is there in the settings of a 4630 and a 4640 pump? I really don't want to go much over the 155 hp mark.
Thanks in advance for the help,
Shane
G/MAN
01-19-2006 10:15:00
 Re: 4630/4640 Fuel Pump in reply to Shane S, 01-19-2006 08:40:02
I don't know about the specific governor settings, but you're putting a pump calibrated for a 466 engine on a 404. I doubt it will make a lot of difference, though. If the 4640 pump is in good operating condition, I don't see any reason you can't bolt it on and go. If you don't want to go over 155 horsepower, I take that to mean you'll probably be dynoing the tractor at some point, and you'll be able to adjust fuel delivery then to give you the horsepower you want. That's simple to do with the pump installed on the engine, and with the shorter "A" pump, doesn't require removing the oil-filter base. One thing you'll probably notice is more lugging power, as I've heard that recalibrating 4430/4630 pumps to 40-series specs increases low-end torque.
Shane S
01-19-2006 10:48:28
 Re: 4630/4640 Fuel Pump in reply to G/MAN, 01-19-2006 10:15:00
G/MAN,
Thanks for the reply. I think this pump is still the P pump, at least it starts with PES. It looks just like the original 4630 pump I had except it has the hydraulic aneroid. The reason I say it is off a 4640 is because the last four digits on the pump were 3029. According to the Abilene Machine website, that's a 4640 pump. Is that correct?
Thanks again,
Shane
G/MAN
01-19-2006 16:23:48
 Re: 4630/4640 Fuel Pump in reply to Shane S, 01-19-2006 10:48:28
I checked a 4650 with an "A" pump on it, and it has the same "PES" prefix on it, so that's a Bosch thing across the "P" and "A" pumps. I thought I had seen it on several different pumps. I could look up the part number of the pump, but if Abilene says it's a 4640 pump, it probably is.
G/MAN
01-19-2006 13:24:15
JDBert is correct, the 4640s used the Bosch "A" pump, while the 4840s use the "P". Same goes with the 4650 and 4850, etc. The easiest way to distinguish the pumps is by the shape of the plunger housing in the center of the pump. The "A" pumps come to more of a taper as the housing goes up, and the top surface where the delivery valves mount is much narrower than on a "P". An "A" pump is also shorter, and I'd have to double check, but I'm not so sure that the shoulder that mounts in the block might not have a bigger O.D. as well, which means that a "P" pump might not physically fit in the block bore for an "A" pump. I've had many of each on and off tractors, but have never grabbed a caliper to check, but I came across that little tidbit while researching for a 55/60-series article I wrote for Tractor Shop. I think we have a 4640 or two sitting outside, so I'll try to get some pump numbers and post back later. I think that "PES" might be a standard Bosch serial number prefix, regardless of pump model.
4020dt
01-20-2006 03:19:22
 Re: 4630/4640 Fuel Pump in reply to G/MAN, 01-19-2006 13:24:15
PES6P = P pump
PES6A = A pump
P pump has larger mounting flange , P and A pumps cannot be interchanged on the same block . Like already stated only 4840's had the P pump , 46 and 44's had A pumps . A 44-4640 pump will fit later 44-4630 with the KDEL injectors , I don't think the injector lines from the KDL style injectors (early 44-4630) will hook up to the later pump .
G/MAN
01-20-2006 07:28:17
 Re: 4630/4640 Fuel Pump in reply to 4020dt, 01-20-2006 03:19:22
It probably wouldn't be too hard for a competent machine shop to machine out the bore for a "P" pump, would it? Or are the studs on a different dimension also?
Shane S.
01-20-2006 05:43:29
Sorry guys.... I guess they are both A pumps, not P pumps as I thought. The PES threw me off. Sorry for all the confusion. I think I am going to just put the 4640 pump on my 4630 without re-calibrating. The main reason I didn't want too much power is because this is all going in a 4520 tractor with a Syncro. Should be fine, but I definitely don't want any durability issues. Do you guys see a problem?????
Thanks again for all the help guys.
Shane
G/MAN
01-20-2006 07:27:21
 Re: 4630/4640 Fuel Pump in reply to Shane S., 01-20-2006 05:43:29
If the rest of the tractor is in good shape, a 4520 should be able to handle 150 horsepower pretty easily.
G/MAN
01-20-2006 07:26:32
If everything is in good shape to start with, a 4520 should be able to handle 150 horsepower pretty easily.
JDBert
01-19-2006 10:57:40
4640's have a "A" series pump 4840's have a "P" series.
