JD 350 crawler cousin in ag model
Matt
11-18-1999 11:33:52
Anybody know what ag model came with the same 3 cylinder diesel engine, and transmission with reverser as a JD 350 crawler. Just wondering and looking for parts sources in ag family.
Steamer
11-19-1999 15:32:13
 Re: JD 350 crawler cousin in ag model in reply to Matt, 11-18-1999 11:33:52
The engine in my JD350 crawler was the same in my 1520 ag tractor. The rest of the driveline isn't like any of the other ag tractors. The ag tractors in that size used a dual-lever (range and speeds) collar shift transmission, while the JD350 I had used a single lever 5-speed transmission.
The 1010 used the same 5-speed as the 420/430 tractors, and my 420c's transmission was different than the JD350's, so that suggestion isn't going to work. The direction reverser in my 420c was different than the JD350's, too. Everything on the JD350 was larger and heavier than on the 420c.
Actually, it was a bit too large and heavy for anything I needed to do with it. That's why I kept the 420c and sold off the JD350. Perhaps someone else has a list of other industrial wheel tractor models that shared the D/R and trans.....
ROBERT
11-18-1999 15:59:41
the eng was used in 830,1020,,1530,2140,300,301,302,310
and more ,not all the same cid
the power tran is close to a 1010 and i say only close
good luck
ROBERT
