B throttle linkage (again)
Doug L
01-18-2006 23:26:45
Is there anything other then the rod that connects the carburetor to the govenor arm and the rod that connects the govenor spring to the lower arm on the tower involved in a B carburetor linkage? When I push the lever forward the govenor spring pulls backwards and when I pull the throttle back the govenor spring goes forward. The govenor arm follows the spring but does not operate the carburetor linkage. The rod from the carb to the govenor arm appears to be too long and I can not shorten it anymore. Is the govenor arm and the govenor upposed to have any other connections to them? Could one of the more computer savvy folks post a photo? Very frustrated. Thanks Doug
Pappy
01-19-2006 19:57:22
 Re: B throttle linkage (again) in reply to Doug L, 01-18-2006 23:26:45
I have been reading your post, but have not read what happens when you remove the throttle rod from the carburetor and operate the throttle by hand. Is it free?? If not, you have found the problem.
John T
01-19-2006 06:53:25
Doug, just where (how long) is the rod from the governor to the carbs throttle set now??? With her not running and the rod removed at the carbs throttle, set the hand throttle to wide open and hold the carbs throttle wide open and adjust the rod length so its 1/2 hole SHORT of dropping down into the throttle. Then install it and be sure the lil cotter key at the bottom or any linkages up top arent binding up. See if that makes any difference???
John T
RAH
01-19-2006 07:34:44
 Re: B throttle linkage (again) in reply to John T, 01-19-2006 06:53:25
Your phrase, "Then install it and be sure the lil cotter key at the bottom or any linkages up top arent binding up" is frequently not given its due. After working on a number of carburators I am convinced that cotter pin should be snug with little or no end play. When a young pup on the farm we had a A that had a tendency to "run away". It happened if you stopped to shift down on a very hard pull, or at the end of the field when the impliment was lifted. The dealer remedy - full choke!, whereupon the A would send a plume of 1/2 burned distillate half ways across an 80 rod field on a breezy spring day.
Mike M
01-19-2006 09:28:18
 Re: B throttle linkage (again) in reply to RAH, 01-19-2006 07:34:44
I use the next size smaller cotter pin in the bottom hole on most as the ones that actually fit the hole are sometimes too thick and rub the side.
I have seen some with NO pin in them ? I still can't see how they didn't pop out ????? as even if I try that when setting up my linkage it pops right out.
