JD 50 Engine Overhaul to increase horsepower
Tye W
01-18-2006 17:16:56
I am rebuilding the engine in my 50 in the next couple of months. I like to see that engine meet or exceed the 40 hp mark. What kinds of things can I do to increase its power? I've heard of some guys taking a 520 head and putting it on the 50. Is that a good thing to do? I know power blocks are a sure fire way to get more power but I wouldn't have the slightest idea where to start looking for one of them. Buying a 520 with factory modifications is out of the question. My tractor has been in the family all its life so I'm going to keep the tractor- it just needs a engine rebuild and Id like to add a couple of ponies for practical purposes. If anyone knows of ways to increase power so I can use the tractor to farm with, Id appreciate any input. --Tye
John Van Valkenburgh
01-19-2006 18:20:34
 Re: JD 50 Engine Overhaul to increase horsepower in reply to Tye W, 01-18-2006 17:16:56
Tye,
Take good notes when you do the rebuild to give me when I do my engine! Mine's still making power but the valve train ticks louder than an old sewing machine. I had pretty much planned on rebuilding to stock except in areas where I might bolster overall reliability. Even at stock the old 50 makes pretty good power when used at the lower gears. I had thought of using a 520 head but I had not looked into it.
Just a thought, you might want to talk to Mark W on this board. He's in the middle of rebuilding his '53 50 and from looking at the pics, doing a nice job.
Best of luck and let me know how it's going.
John
1953 Model 50
Mike M
01-19-2006 02:34:15
If you need a 40 hp + tractor get a 60 or a 520,530,620,630 you will be way better off.
buickanddeere
01-18-2006 19:34:47
Dry filter aircleaner conversion. Port match the carb inlet/outlet and manifolds to head. Blend the rough edges and burrs from the valve bowls and around the guide/seat. Three angle valve job. A modest cam from Robert's Carb. New valve guides. New valve springs or test the old ones to be certain they have enough pressure. LP pistons. Tune the engine on a dyno to find the ideal mixture and timing. Some real suprises sometimes. Don't run the engine at full load and lugged down for extended periods.
Tye W
01-19-2006 06:16:45
 Re: JD 50 Engine Overhaul to increase horsepower in reply to buickanddeere, 01-18-2006 19:34:47
buickanddeere, What's the problem with lugging the engine down at full load for extended periods of time? Thanks for the help. --Tye
buickanddeere
01-19-2006 15:14:33
 Re: JD 50 Engine Overhaul to increase horsepower in reply to Tye W, 01-19-2006 06:16:45
Exceeding factory max cylinder pressure and torque specs. This causes extra wear and shortens component life. So if the mods just moved the lb ft torque peak up from say 850 to 1250 rpms. Wear would be less than if hte lb ft of torque was increased at 850 prms and the engine lugged. Even a stock engine wears faster when operated at say 850 rpm with the govenor wide open and putting out e.g. 28HP. V.s. the same engine making 28 HP at 1250 rpm with the govenor at 80% open. So these operators who pound around with thier two cylinder at partial rpms and heavily loaded are not "saving the engine".
