JD D
Ken Hoover
01-18-2006 08:01:28
I have an early D with the generator bracket off the governor box. I can't see any way to get the belt on without disconnecting the fan shaft. Am I missing something?
Glen in TX
01-18-2006 12:34:54
 Re: JD D in reply to Ken Hoover, 01-18-2006 08:01:28
Also probably not enough room with radiator on but I know there is with radiator off is to take the two bolts loose on fan shaft bearing at water pipe and then governor flange bolts out and it will slide forward to get a belt on also.
Glen in TX
01-18-2006 12:07:39
With that split pulley between the governor and water pipe that's the only way to get a 1 piece belt on there by removing the water pipe or the governor unfortunately. I've got some old time belt splice kits that are a metal hinge that fit together with a pin but only in a B V belt size. You might find someone that has those to put a belt together with on there. Easiest thing to do would be to find a source local for the link type V belts that you fit to length you need but those aren't cheap if they come in a 5ft. minimum length for about $30. The extra length may come in handy later for something else. You can find those through a auto supply or industrial bearing & belt supply.
www.grainger.com
www.mcmaster.com
www.motionindustries.com
