B throttle and carb
Doug L
01-17-2006 22:14:14
I have a 1953 B that I restored, but was missing the carburetor when I got it. I just got a rebuilt on ebay and went to put it on and realized I did not understand the govenor as well as I thought. I hooked up the throttle linkage to the top of the carb and the choke to the side linkage towards the front of the carb. That appears inpossible to mess up. The stumper is that when I pull the throttle lever on the tower (to give it more gas) the linkage on the carb does not move. The only thing that moves is the thin band on the govenor that parallels the govenor lever. The govenor lever does not move and the carb linkage does not move. Is this correct? Only thing that moves when I move the throttle lever is the thin band of metal. Once the tractor is running does the govenor lever move to move the throttle lever on the carb? I've never seen the tractor whole or running and am not yet too familiar with the John Deere methods. Yet. Please advise on how this should operate and function. Thanks Doug L
Dave NE IA
01-18-2006 16:12:59
 Re: B throttle and carb in reply to Doug L, 01-17-2006 22:14:14
Did you try playing with it before installing the rebuilt carb? Rebuild is a very big word when dealing with many things and for sure carbs are near the top of the list. My experience with shade tree rebuilds would suggest checking out the bushing on the throttle shaft, if not reamed properly or driven to deep it could cause a bind. It should go (throttle shaft within carb when unhooked) without any binding. A very easy and no cost fix. (not to often do you hear those words) Dave NE IA
rla
01-18-2006 07:04:12
Hand throttle lever pulled back is idle speed
ahead is wide open. With linkage rod diconnected
from govener to carb, hand throttle set to wide
open, rod from govener should be 1/2 hole short
from falling into carb with throttle plate heald
wide open position.
Bob
01-17-2006 22:51:06
The "thin band of metal" is the governor spring.
When you move the throttle lever, and it tugs un the flat spring, the governor arm should move, moving the carburetor throttle lever with it. As the engine accelerates, the governor will "fight" the tug of the flat spring, and move the throttle butterfly towards the "closed" postion, keeping the engine's speed under governor control.
It sounds like your linkage is mis-adjusted, something is stuck, or there are internal governor problems.
