jdemaris
01-17-2006 20:31:06
1010 diesel 12 to 1 ? ? in reply to msb, 01-17-2006 18:56:12
Any 1010 or 2010 diesel I've ever been aware of runs 19 to 1 compression, not 12 to 1. I doubt it could even run at 12 to one compression unless the engine was kept at 230 degrees F or higher. Also, when set-up properly the engines do not smoke much more than any other diesel once warmed up. Some of the early pumps have a load-advance, whereas later, or replacement pumps have a speed-advance. If either advance system is not working or adjusted properly, a lot of smoke - blue, white, or somethings both will be produced. And, in regard to indirect injection - that in itself does not make a smoking or inefficient engine. There are many that start well and run clean once warmed up - and in many cases, they are more efficient than their direct-injected counterparts. The 1010 and 2010 engines do have a convoluted starting system if judged by today's standards considering the glow-plugs and hand-primer system, but they worked fine when all was right. If the engine is in good shape mechanically, there's a good chance that adjusting the static timing and the advance will make a big difference. Same also goes for the fuel delivery if someone has already turned it up too high. If the pump was off, you could check the setting with a micrometer across the pump rollers. But, with the pump on the engine - setting fuel delivery would be done by trial and error - i.e. turn it down until you start loosing power under load, then turn it back up 1/8 turn. If it starts hard after that, turn it up another 1/8 turn. In regard to the Bon Ami treatment - yeah - it was standard procedure in our shop in the 60s and early 70s for problem - engines. Personally, I think it was a waste of time - but we did it at the Deere dealership, and the Case dealer next-door also did it - when an engine job was not working out well. We'd load them real heavy on the dyno first - if they had a PTO. Usually not he case with crawlers and log skidders though. In retrospect - it usually had to be used on those jobs when someone did a lousy job of honing the cylinders - or the cylinders were scored, and/or the pistons had worn ring-grooves. Bon Ami - on a few occasions would stop an engine from smoking for awhile - but certainly didn't cure anything in the long-run. If a cylinder wall is in good shape (i.e. not scored, round, and a good cross-hatch pattern), and the ring-grooves are tight against the rings, there will rarely be a problem unless the engine is not run properly when first started. We had a few newly rebuilt engines that had "ring walking" problems, and all the ring-gaps would line up with each other. I suspect that is from not loading a new engine properly when first run. Bon Ami won't fix that. In fact, by the late 70s, Deere told us warranty would be voided on engine parts if they caught us using it.
