3010D Charging Problem
Bob
10-27-2003 08:05:22
When temps are above 30 tractor will hold a charge and start easily for about 2 months..... @ 25 hours of running time & 25 starts. When cold and requires more cranking, batteries will run down easily. Has original generator, will rebuilt if necessary or go to alternator, or is there some other solution?
Rodney A. Johnson
10-28-2003 06:57:31
 Re: 3010D Charging Problem in reply to Bob, 10-27-2003 08:05:22
I have a 3010D with the old 24 volt setup. I had a similar problem not too long ago. I took an older am meter I didn't care about and checked to see if there was a draw on the battery when things were "suppose to be" off. I found that I had a 6 micro amp leak. So now what I do is just disconnect the battery when it sits for any length of time.
I had the same thing happen to my 4020D which was also 24 volt. Only this one had a 17 milliamp draw. I ended up converting that one to 12 volt when the starter fried and have no more problems (shorts were in the starter or generator).
In both cases, the batterys of the tractors were only a couple years old and in good shape.
Just something else you may want to check into.
Bob
10-28-2003 07:47:28
 Re: Re: 3010D Charging Problem in reply to Rodney A. Johnson, 10-28-2003 06:57:31
The tractor has 2 6 volt batteries hooked in series, i believe, to obtain 12 volts
G-MAN
10-27-2003 10:53:29
There are some simple things to check. Check your system voltage with the engine running at a fast idle. Also check the condition of your battery cables and ends, and make sure they make good connection to the battery posts. It would also be a good idea to remove the batteries, top them off with distilled water, give them a full charge, and load-test them. If they're good, they should maintain around 12 volts or so when pulled down to half of their CCA rating for 15 seconds, although it can vary with temperature. If you pull them down and the fall on their faces - down to 10.5 volts or less, you need new batteries. Just remember to FULLY charge them before testing - preferrably several hours on the low setting of the charger. When fully charged, their voltage should be about 13.2 volts - 2.2 volts per cell.
R. Marg
10-27-2003 09:44:18
sounds like old batterys when its cold you get less out of the battery and if they are old you get even less hope this helps
