F-I-T Electrolysis Question
Trigg
01-17-2006 01:52:08
I am still using my godsend of a tank per your directions. What a great tool for a lazy guy like me!! I cant believe everyone doesn't do this Thanks a million !!!! Anyway, have you ever had an issue where the process damaged parts like steel bushings or bearing parts? I have been reluctant for fear of pitting those surfaces.
F-I-T
01-17-2006 12:03:57
 Re: F-I-T Electrolysis Question in reply to Trigg, 01-17-2006 01:52:08
Trigg:
Glad it is working out for you.
As to etching/eroding metal like bushings, I have "cooked" bronze, brass, copper, galvanized, iron, steel, stainless steel, aluminum, and magnesium, and the only effect I can see is on the white metals (aluminum, pot metal, magnesium).
I miked and inspected before and after on brass and bronze and see no effect at all. Copper, I can't say I had a problem, but someone else reported that using copper wire for the link between the buss and the parts made the solution turn a bit orange. The zinc turns a but dark, so I wonder if it isn't breaking down, or picking up a loose metal salt from the bath.
So, I would, for my own uses, consider it safe for iron, steels, bronze and brass, but would avoid aluminum, magnesium, pot metal, galvanized (zinc), and possibly copper. It seems that anything that might react with a strong base such as lye (Sodium Hydroxide) might be at risk. As long as you don't cook a zinc die cast carburetor, a mag housing, or aluminum pistons, you should be just fine.
That's my story and I'm sticking to it until a better one comes along!
Frank
