4020 Does it use a packing ring?
toby
01-16-2006 17:06:51
Rebuilding a 4020 with serial 1539011. Block number is R40890R. I was sent two o-rings in one packet and 2 o-rings and a packing ring in the other. Do I use the one with or without the packing. I thought all john deeres used a packing ring on the sleeve but now I see some don't. Thanks for any help.
Toby
msb
01-16-2006 19:06:35
 Re: 4020 Does it use a packing ring? in reply to toby, 01-16-2006 17:06:51
Does your block have weep holes in it?I think the R 40890 does.Take a real good look at the top o ring groove.If it is pitted then you can use the third o ring in the weep hole ring groove.I am presently overhauling a 3020 diesel that someone had used the 3rd o ring since the top grove was pitted.The tractor had water in the oil and is a real mess.Had they chosen to repair the pitted grooves it might have kept from causing so much damage since the coolant would have shown up coming out the weep holes.Some machine shops can repair the pitted grooves or with a little patience they can be repaired with JB Weld like I am doing to this 3020.Lots of people use the weep hole groove,but I am not a fan of it myself.
toby
01-17-2006 04:30:29
 Re: 4020 Does it use a packing ring? in reply to msb, 01-16-2006 19:06:35
The ring I was referring too is the square packing ring that slides on the sleeve. I thought they all used it but my dealer says no. I am glad to know that I can use the weep hole area for a ring.
Toby
