Proper press fit of valve guides in the head for l
Paul_IN
01-16-2006 15:34:49
Have any of you guys had difficulty replacing a set of valve guides in a 2 cylinder head? We are redoing one, its a 1952 model B, and I got new guides at JD and went to put them in today. Well, I didn't measure them against the old ones thinking they were sized properly and promptly ruined the first one I tried as it got about 1/2 way down and then wouldn't budge. So out came the micrometer and the new ones are close to a thousandth bigger that the old ones. The bores are about 8 tenths to 1.5 thousandths smaller than the old guides. My service manual doesn't say any more than to press them in and then ream the ID to proper fit. What do you think the proper press fit should be? I'm thinking I want to ream out the head until I have a 1 thousandths tight fit? Your thoughts are appreciated.
Mike M
01-17-2006 06:28:53
 Re: Proper press fit of valve guides in the head f in reply to Paul_IN, 01-16-2006 15:34:49
I have installed many many sets of JD valve guides in the past,none real recent. I never had a problem with them and never had to ream the insides either. JD press fit stuff like bushings and such never seem to be tight enough tolerance for NEW parts to me. They usually press out hard. I use a 10 ton el chepo Harbor Freight press. I really clean out the bore in the head real good then put a little white lithium engine assembly lube in the head and some on the guides. I use a homemade piloted arbor and put a mark on the side of it for proper depth then press them in from the face of the head (side towards piston)this is usually where they measure the depth from.
Paul_IN
01-17-2006 18:56:40
 Guides are in in reply to Mike M, 01-17-2006 06:28:53
Thanks for the posts, I put them in tonight and didn't mess up.
Greg_Ky
01-16-2006 15:43:46
Are you using an air chisel with a piloted arbor?
Are you installing them from the valve pocket?
I have installed alot of guides and once in a while you will "HANG" one. Oil the O.D. before installing.
Paul_IN
01-16-2006 18:24:49
 Re: Proper press fit of valve guides in the head f in reply to Greg_Ky, 01-16-2006 15:43:46
I used our shop press with a plate on top of the guide to push against. I was installing from the front side of the head so that the chamfered end of the guide was entering first. Started the guide and then relieved pressure to try and allow any self-righting to occur. Parts were clean and dry, I did not think oil was beneficial in tight press fit applications. Maybe that is the trick I needed. Thanks for the post.
