a farmers harley..aka ..2010 JD what is this???
Brockway 361
01-16-2006 12:19:41
What is the odd looking,flat bar with a notch in the end of it that is locate on the clutch side and very near the floorboard on a 2010 JD??? it has me perplexed,baffeld,and confused. I also waant to thank the people who responded to my distributor question last week. (it wound up being a prestolite)
donmyeil
01-16-2006 13:12:00
 Re: a farmers harley..aka ..2010 JD what is thi in reply to Brockway 361, 01-16-2006 12:19:41
Thats a manual disconnect for the hyd. pump for cold weather starting.
Brockway361
01-17-2006 04:56:26
 Re: a farmers harley..aka ..2010 JD what is thi in reply to donmyeil, 01-16-2006 13:12:00
Thanks for the heads up on the lever. Going to try it out today.
billde
01-17-2006 19:51:26
 Re: a farmers harley..aka ..2010 JD what is thi in reply to Brockway361, 01-17-2006 04:56:26
That lever is the lockout for the hyd pump as previously stated. If you decide to use it, once the tractor is warmed up, shut the engine off before engaging the hyd pump. Just like the 2 bangers this pump was not designed to be engaged with the engine running.
