JD 50 Dyno'd Today
Tye W
01-16-2006 08:10:48
Had the 50 at the dealer this morning- getting it dyno'd. It showed 22 horsepower. The Tech said that the dyno may show a little bit more if the oil in it was warm. Ok so possibly 24 or 25 horsepower. When we had it wide open spinning the dyno, I noticed the tractor was putting out a lot of white smoke out of the crankcase ventilation tube comming out from the valve cover. Seemed like a lot of blow-by to me. The tractor has new wires, plugs, points and so on. I love this tractor-she's my worker. Am I due for an overhaul? Opinions welcomed and appreciated. Thanks.
BushogPapa
01-16-2006 18:56:49
 Re: JD 50 Dyno'd Today in reply to Tye W, 01-16-2006 08:10:48
It is probably mostly crankcase Moisture evaporating off...!!
I bet that if you work it steady for a couple hours that it will almost entirely disappear..
Ron..
B-maniac
01-16-2006 18:25:03
If the valve guids are worn the first indicator is sucking oil from rocker arm area on intake stroke and will blue smoke especially on deceleration.If your valves are seated (ie runs and starts good) anything you have blowing out the crankcase IS blowing past the rings. A cracket head would do it ,but it wouldn't run right. Doesn't sound like anything to worry about. WORK it once.
buickanddeere
01-16-2006 16:24:33
Blowby on every engine increases with rpm and combustion chamber pressure. Dad's 50 would only make 28HP on the dyno until I held the throttle wide open by hand. The governor spring is getting old and weak on that one. 33HP afterwards. The white vapour maybe just old crankcase ick that has been in there for years. Putting the tractor under full load on the dyno maybe warming the entire engine for the 1st time in years. The dyno could be suspect as well as previously stated. Way down at 25HP maybe at the bottom range of the dyne�s scale. Usually test equipment is preferred to operate in it's 10 to 90% range. I agree a full days ploughing at near max HP may shake more ick and goo from the engine internals.
DickD
01-16-2006 15:22:19
Tye; The 50 is really a nice little tractor. I don't know how much your tractor is used, but before I tore it down, I would find a way to put the engine under a load for several hours. I find this does wonders for mine, My 2 cents worth
THANK YOU EVERYONE!
01-16-2006 18:49:24
 Re: JD 50 Dyno'd Today in reply to DickD, 01-16-2006 15:22:19
I think Iam going to overhaul the 50. Technically it does meet all my power needs at the moment but in the next couple of years I am looking to move into my first house and hopefully a few acres to go with it. I want to make sure my tractor is running it's best. I am definately going to give it a work out this spring -I've been building a 3X12 plow for it, so we'll see how it goes. Thanks for all the help. --Tye
buickanddeere
01-17-2006 15:44:25
 Re: JD 50 Dyno'd Today in reply to THANK YOU EVERYONE!, 01-16-2006 18:49:24
If rebuilding it don't forget or skip over the cam and cam followers. They do suffer wear not visible to the eye and can cause loss of power, rough operation etc. The compression ratio was very conservative on those engines too. A set of model 50 LP pistons will run on pump gas and perk her up a notch or two. The oilbath aircleaners often need the mesh boiled out. 50+ years of dirt,water and oil can get set pretty hard in there.
Mike M
01-17-2006 06:58:45
I'm all for tearing into one and checking it out if I'm going to keep it. I haven't seen a 50 year old tractor yet that didn't need something if you go looking. If it's really bad once you get in there (like broken rings if it has alum. pistons) you will be very glad you tore it apart. If it's not too bad and just needs a valve job some gaskets and rings it shouldn't cost too much to do.
Another thing I'm big on doing is too rebuild all the things that get overlooked (like starters,waterpumps,generators,carbs.,fuel shut off bowls,dist.) until they don't work and this is usually at the worst time when you need it the most. Simple things like unhooking all the wiring connections and cleaning them will save alot of greif and doesn't cost anything but time. When I climb up on one of my tractors I want it to go! I don't want to be messing around with it when I need it.
F-I-T
01-16-2006 13:56:12
Tye:
One other thing to consider. I have an old M&W dyno, and I'm pretty certain that it does not read in a linear fashion from top to bottom of the scale, so it is very possible that you could have a scale error (a significant one at that) on the low power end. Truth be told unless you have an accurate Prony brake or an eddy current instrument, the readings may only be useful for realative comparisons. For instance, if you dynoed it, then did a tune up, then re-checked it on the same machine, you could see an X% improvement, but saying you gained exactly x.234 HP is going to be tough depending on the dyno they used.
I know the dealers will tell you their machine has always "just been checked out and calibrated", but I would vote for leaving your '50' alone if it is doing the job, not blowing a ton of blue smoke, and meeting your power needs.
My two cents.
Frank
Mike M
01-16-2006 09:36:42
Blow By comes from the rings/cyl. bore not the valve guides and it sounds like shes overdue for an overhaul you should be makeing at least 31 HP your compression pressure you tested is low also. Bottom line is if it does what you need to do and starts and runs good and doesn't foul plugs it's up to you if you want to spend the money on it or not.
55 50
01-16-2006 10:38:05
 Re: JD 50 Dyno'd Today in reply to Mike M, 01-16-2006 09:36:42
Blow-by by your definition is what? Crankcase only generated? Not any exhaust gas? If exhaust gas passes the rings and cylinders on the power stroke, then that would get to the crankcase and be part of the blow-by in my way of thinking. And if exhaust gasses get past a bad exhaust valve, they certainly could get past a bad valve guide and be part of blow-by also. So I disagree with your statement that blow-by doesn't come from bad valve guides.
Mike M
01-16-2006 11:16:40
 Re: JD 50 Dyno'd Today in reply to 55 50, 01-16-2006 10:38:05
Disagree with me that's fine. But whatever valve leakage you have (can't be much as it still runs) is going to take the path of least resistance and the exhaust pipe hole or intake port is going to offer a whole lot less resistance than an overly worn valve guide.
I've never seen any referance material ever stating blow-by as coming from any place other than worn rings and cylinder to bore clearance.If you have some please post it.
55 50
01-16-2006 12:20:12
 Re: JD 50 Dyno'd Today in reply to Mike M, 01-16-2006 11:16:40
I haven"t any reference to verify what I said and after thinking the entire 4 cycle engine process through, I see my old brain clearly led me astray. Thank for setting me straight!
wimpfarm
01-16-2006 09:27:48
The valve guides might be wore allowing blow by . If the tractor runs good & is acceptable to you I wouldn't worry about it, just keep an eye on things & enjoy it .
If you use this tractor a few hundred hours a year then I might consider rings head work & bearings .
Terry.....
F-I-T
01-16-2006 08:23:37
What's the compression before and after adding a tsp of oil to each cylinder to seal the rings?
Does it use any oil while working?
Tye W
01-16-2006 08:41:07
 Re: JD 50 Dyno'd Today in reply to F-I-T, 01-16-2006 08:23:37
If memory serves me right it had 100 psi in one cylinder and 105 psi in the other. Haven't tried the teaspoon of oil yet. It will use a little oil when I work it. Thanks.
55 50
01-16-2006 10:28:13
 Re: JD 50 Dyno'd Today in reply to Tye W, 01-16-2006 08:41:07
Model 50 Service Manual (SM2010) says compression should be 120 PSI on a "new" engine with rings seated and 200 RPM cranking speed and throttle wide open and engine at operating temperature. Variation from one cylinder to the other should be no more than 10 PSI.
