39 jd b
owen reed
01-15-2006 19:08:02
I"ll try this again. Does anyone have any information on OEM"s of electric start equipment for jd "b"s" back in the early "40"s???
Glen in TX
01-15-2006 21:49:23
 Re: 39 jd b in reply to owen reed, 01-15-2006 19:08:02
Like Duane said they used Delco Remy brand. Not sure what info you are looking for so here goes.. Parts are listed for them in the JD B parts catalogs PC330 (for styled B) and PC676 (unstyled B). Application charts and wiring diagrams for 2 cyld. electrical systems are shown in the JD SM2029 Electrical service manual. It gives applications charts and some service specs. for starters, generators, regulators, relays, distributors and magnetos. SM2029 covers magneto repair some also. For more extensive testing and repairs of the Delco electrical systems used on 2 cyld. JDs you would need to see the SM2000 Tractors in General service manual that covers electrical unit repairs, mag repair, carb repair, engine valve grinding specs, and general shop tool usage and safety. Electrical service shops had Delco Remy service manuals also and I have those and parts manuals but it's the same info you will find in the JD manuals that will pertain more to your tractor. The SM2029 and SM2000 and parts catalogs are available from JD yet through your dealer or direct from JD publications 800-522-7448.
Duane Larson
01-15-2006 19:33:32
Owen,
Starting and lighting equipment in the early '40's and since is built by Delco Remy - generators, starters, regulators, etc. Are you looking for DR models of these units?
Some aftermarket electric starting equipment was available - if that is what you are referring to post back and I'll try to dig up some of that info.
