60 carb Question
LoneStar
01-15-2006 17:32:21
Finally found the reason while my 60 would not stay running. It seems that the choke was on because of a broken pin on the outside of the carb. I tried to get the steel pin out of the brass rod but failed. I drilled out the pin and replaced it with a similiar pin (i guess the original cannot be found). My problem now is that I cannot figure out how the spring goes inside the plastic piece so the choke opens and closes right. Anyone have a ideas how this works?
Duane Larson
01-15-2006 18:21:27
 Re: 60 carb Question in reply to LoneStar, 01-15-2006 17:32:21
LoneStar,
I gather the choke shaft pin broke - they can be tricky to get out, but sounds like you have solved that problem. Now to get the choke lever (pot metal, not plastic) properly arranged with the choke spring. With the choke shaft turned so the plates are in the "choke open" position, the pin you replaced should be in a "1 o'clock-7 o'clock" position. Place the spring on the shaft with the loop end on first, and hook the loop end around the 7 o'clock pin. The outside end of the spring should now be pointing in toward the carb, and also be pointing about at the 1 o'clock part of the pin. Hold the choke lever up like it is going to be placed in position. Looking inside the cavity where the spring fits, you will see a wedge of metal cast in the hole. One edge of the metal (the "right-hand" edge) forms a right angle with the outer edge of the casting, and the back side of the edge (the "left-hand" edge) does not. Hold the choke plates in the open position so they do not rotate. Hold the lever such that the end of the spring pointing in toward the pin goes behind the left-hand edge of the wedge. With that piece of the spring in place, slightly rotate the lever back such that the spring begins to wind up, and the part of the pin in the 1 o'clock position slips behind the right-hand edge of the wedge. It does not take more than a few (10 deg or so) of rotation. The spring will try to slip off the wedge, but it will get caught with persistence. Then push the choke lever in so it is positioned and put the bolt with the spring and washers properly positioned in place. Try opening and closing the choke and all should work.
Lonestar
01-15-2006 21:37:56
 Re: 60 carb Question in reply to Duane Larson, 01-15-2006 18:21:27
I dont know how I managed this, but my spring got somehow bent or was bent while it broke. Can a person still get this spring?
Duane Larson
01-16-2006 05:57:41
 Re: 60 carb Question in reply to Lonestar, 01-15-2006 21:37:56
Lonestar,
Yes, ask your dealer to order one R10099 - it should cost about $5.99.
LoneStar
01-16-2006 09:22:26
 Re: 60 carb Question in reply to Duane Larson, 01-16-2006 05:57:41
Thanks
