my buddies 5020
boogs
01-15-2006 15:40:03
My neighbor just got a 5020,,theres a lever flush with the operators platform by your right foot,its got a hole to reach down and pull up a small strap,, anybody know what its for,,thanks boogs
MSM
01-15-2006 16:36:13
 Re: my buddies 5020 in reply to boogs, 01-15-2006 15:40:03
Manual disconnect for the PTO. Engage it with engine off.
boogs
01-15-2006 17:17:59
 Re: my buddies 5020 in reply to MSM, 01-15-2006 16:36:13
Man your a life saver,,not only was the suspense killing me,,but his pto didnt work either,,,whata ya do, turn it right or left,,once, twice,,,thanks boogs
Glen in TX
01-15-2006 19:18:47
 Re: my buddies 5020 in reply to boogs, 01-15-2006 17:17:59
PTO drive disconnect for when PTO is not being used. Same thing on a 5010. The PTO drive is connected when the lever is the locked position with beveled edge of the lever up. To disconnect the drive with the engine stopped or slowly idling, lift the lever and rotate it 180 degrees. Drop the lever back into the locking slot. To connect PTO drive, stop the engine, lift the lever and rotate it 180 degrees. If you have trouble rotating the lever bump the starter some while holding pressure on the lever. So when the beveled edge of lever on floor is up and with engine running the PTO should engage when dash lever is pushed forward.
Does...
01-17-2006 11:06:02
 Re: my buddies 5020 in reply to Glen in TX, 01-15-2006 19:18:47
..a 6030 have one of these as well?
Glen in TX
01-17-2006 13:03:10
 Re: my buddies 5020 in reply to Does..., 01-17-2006 11:06:02
Not that I'm aware of if 6030 did. Possibly some early ones or maybe none? Late 6030 parts catalog doesn't show anything on a disconnect but the holes were still there on the floor plate. I think the PTO disconnect is just something that was a design carryover from the 2 cyld. days on wheatland area models when earlier a PTO wasn't even ordered on them or needed.
boogs
01-15-2006 19:56:39
thanks,,made my neighbor happy,,he thought he got a headache,I should say checkbook ache,,,boogs
Glen in TX
01-16-2006 12:57:06
 Re: my buddies 5020 in reply to boogs, 01-15-2006 19:56:39
Hopefully his PTO works. Good luck.
