 Malcolm, I would disagree. The JD paint is the old synthetic enamel formula from the '60's, and if you want it green for a while, then that's the stuff to use. If you want a true auomotive finish that will resist sun, chips, and fuel, then you really need to use acrylic enamel or better yet a urethane. On my nice projects I use acrylic enamel, color sand, then clear coat. On implements like m 45 W loader, I used Deere paint with a synthetic enamel hardener, and it is no way as nice a paint from a durablility stand point as acrylic enamel and it's hardener. I've painted dozens of tractors and implements over the years with the synthol Deere paint, and it's just rustoleum in a JOhn Deere can. Now, believe it or not, you can buy Limco 1-2-3 which is an acrylic enamel chemistry and it is right at the same price as Deere synthol. It's not a bad paint. As for automotive codes, I use PPG for green, and it is code PPG DAR 46180 (46180 is the doce, the DAR is the acrylic enamel disignator), and in the yellow I use a DuPont Ful-Acryl II 2612. I just have never found a good code for the yellow in PPG. I used these codes on my '70' pictured here. The green and yellow matches the Deere product from either a spray can or a gallon can. Frank
