1948 Model A battery question ??
Sam F.
01-15-2006 12:22:06
1948 Dual fuel model A. Originally did they come with 2-6 volt batteries ?? Positive or negative ground. Can you pinpoint where the ground from battery was attached on tractor ?? Length of this cable ?? Braided or copper standed ?? Thanks
Pappy
01-15-2006 13:04:22
 Re: 1948 Model A battery question ?? in reply to Sam F., 01-15-2006 12:22:06
Two six volt batteeries were used.
Positive ground.
Grounding cable was originally hooked to the seat frame (battery box) I believe, but I have mine grounded to the bolt on the end of the rockshaft (right)
To me, this gives a better ground. Original cable was braided, according to the picture in the parts manual. You probably need about 18 to 20 inches of ground cable if you connect it as I did.
If you connect it to the battery box, it could be shorter.
