4020 sway blocks
JD9295
01-15-2006 05:52:58
Anyone got a better way to eliminate sway on the lift arms on a 4020?
Ive got the sway blocks but with a bale mover on I have way to much movement, Ive turned the blocks until there are no more positions to try.
Its always been a problem, just getting on my nerves more as I get older!
Any ideas?? thanks
John in Md.
01-16-2006 06:23:24
 Re: 4020 sway blocks in reply to JD9295, 01-15-2006 05:52:58
If you just want to quiet it. Cut some tire tread and wrap arms, secure with hose clamps. Don't try to make it a snug fit or it will tear it self up. Worked on mine.
Al Epp Waldorf Md
01-15-2006 16:00:19
My 4020 had a lot of side play in the arms where they are attached to the tractor. I just used big washers to shim them up.
ricedaddy
01-15-2006 08:32:31
there are only two positions, so if that won't work for you I would suggest changing you equipment your haveing a problem with.
good luck
jdp
01-15-2006 08:15:36
cut the brackets off of the bale mover and reweld them where they need to be if you afro rig your tractor you will have to change it back to use it on other equipment that was made right in the first place
billyiron
01-15-2006 07:45:38
just redo pins on bale mover,or,Ive seen guys put a piece of flat iron on arms held on with u-bolts,,,billy
JD9295
01-15-2006 07:52:33
 Re: 4020 sway blocks in reply to billyiron, 01-15-2006 07:45:38
tried moving the pins to the inside, but with the blocks on the narrowest part they were to wide.
i was thinking along the lines of cutting some steel and putting behind the blocks and putting in longer bolts but just wanted to see if anyone had anything else first
usually get some pretty good ideas here
720Deere
01-16-2006 08:01:15
 Re: 4020 sway blocks in reply to JD9295, 01-15-2006 07:52:33
You are on the right track! Making a 1/2" (or whatever dimension you need) shim to put behind the blocks is your best option to retain stock function and eliminate butchering of your tractor. It's simple, easily removable and will allow the sway blocks to function exactly as they were designed.
Glen in TX
01-15-2006 12:01:30
I've slit pipe in half to mount on the arms with clamps or bolts to help that slack. You want something removable if it's only doing it with the bale mover or just redo the bale mover hitch. On a 2510 we used a JD quick hitch and still always had too much side sway and just finally welded on some more pipe halves to the lifting arms by sway blocks and used a solid piece of 1 7/16" pump shaft welded all the way across bale mover hitch for quick hitch to grab. Moving heavy round bales especially on ridges is hard on them anyway and less side sway will keep from bumping the arm pins out on you.
