4020 marvel Carb trouble...
Erik in WI
01-14-2006 18:16:55
Had the marvel carb on my 4020 rebuilt by someone who has rebilt it before. When I got it back, the tractor ran rough and smokes because it is getting to much fuel pressure( if I shut the valve off at the tank it runs like a top). If I bypass the pump, and run the tractor on gravity fed fuel, with a full tank, it runs better. If I hook the transfer pump back up and only open the valve on the tank about 1/4 of a turn it runs fine. I sent the carb back and the rebuilder ran it on another 4020 with no problems. any ideas??
msb
01-14-2006 18:52:40
 Re: 4020 marvel Carb trouble... in reply to Erik in WI, 01-14-2006 18:16:55
Maybe you should take a pressure reading on the pump. Unless the pressure is very high the needle and seat should shut off the excess fuel,but it doesn't sound like it is.
msb
01-14-2006 18:52:29
