Clogged air intake
Elk Hunter
01-14-2006 14:26:51
Does anyone know how a 2 cylinder would act if the air intake was clogged? Can't seen to get my "A" started yet. I read in a form archive that this can happen. What does it take to fix that up. Plugs appear to be wet after an attempt. Pulled it with fresh 388's in it and no avail. Ignition checks out ok. Would oil from canister be sucked into carb?
BushogPapa
01-15-2006 16:26:04
 Re: Clogged air intake in reply to Elk Hunter, 01-14-2006 14:26:51
Oil will be pulled into the intake from the Ventilation pump....if the air inlet is plugged by Mud doubers... It will probably Idle fine, but go Very rich and start Smoking real bad under a heavy load... Yep..been there, done that...!!!
Ron..
PAPPY
01-15-2006 13:12:02
Take Popper Dick's advice and just remove the cup from the air cleaner to do the test. No need to start tearing it apart until you find the problem.
tstex
01-15-2006 07:09:23
Gentlemen,
Although i live in Houston, there are billions of mud-dobbers at the country place - everyone is right, they will fill any hole possible...so let's give them some holes!
WHat i do is take some old 2x4's and drill the perfect set of holes: like 80+ of them/board. place the boards near/around your tractor...they will go to those holes first...then all you do is take the board outside and whack it agaist something hard on the 2" side until a majority of the nests break-out...then simply re-apply the board..also, old chicken wire or mesh wire hung on the wall will attract them like flies to a picnic...they are dumb and will keep trying to fill the same holes - you can also put a tarp over your tractor [have to wait until it cools off]. anyway, this seems to keep 95% of the pesky insects out of the areas you do not want.
As mentioned, try by-passing the air-stack by removing the hose to the carb...this will give you all the air you need...
Lastly, whacking that board on a fence post or something is also very self-gratifying - it helps with getting some revenge for all the yrs those little m-dobbers forced me to get dirt out of small holes...
good luck,
tstex
DickD
01-15-2006 07:06:31
BE VERY CAREFFUL If you take the intake on the carb off the breather, and try to start it. If the float happesns to stick, and it backfires, it WILL catch on fire. CAREFUL
REDJD
01-14-2006 20:21:19
I had mud dobbers to stop up the air hole on the back of the fuel converter on my 530LP. It wouldn't start till I found and cleaned it out.
430WLPG
01-14-2006 16:26:54
Take the pipe loose from in front of the carb. and see if it will start then.
Popper Dick
01-14-2006 14:55:56
Elk Hunter,
I have a B that the mud dobbers packed my intake stack plumb full. I had to take it off and flush and tamp with water for quite a while to get it clean. She ran fine after that.
Dick
Elk Hunter
01-14-2006 16:05:16
 Re: Clogged air intake in reply to Popper Dick, 01-14-2006 14:55:56
Dick, that may be my problem. Can you give me some detail about these mud dobbers. I guess I have to take the hood and fuel tank off to get the intake stack off? Also how does the oil canister come into play? -Tom
Popper Dick
01-14-2006 17:34:59
 Re: Clogged air intake in reply to Elk Hunter, 01-14-2006 16:05:16
Tom,
On my "B", as many are, the previous owner cut the hood out around the muffler so he could remove it without removing the hood and tank. So I removed the muffler and had enough room through that opening to remove the upper bolts that hold the air cleaner casting and stack in place. I removed the short piece of hose that connects the air cleaner casting to the intake pipe to carburator and then was able to remove the stack out the bottom.
Before you remove your hood, remove the oil bath can at the bottom of your air cleaner and see if she will start and run. You may not have a mud dobber problem like I had.
Good Luck
Dick
F-I-T
01-14-2006 18:03:36
 Re: Clogged air intake in reply to Popper Dick, 01-14-2006 17:34:59
Sometimes the problem is in the mesh of the canister which is after the oil cup.
I would do like 430WLPG said and remove the air pipe on the carb. Then you for sure know that there should not be any restriction. If that does the trick, then reinstall and work your way back towards the stack.
Frank
Popper Dick
01-14-2006 18:36:08
 Re: Clogged air intake in reply to F-I-T, 01-14-2006 18:03:36
Frank & Tom,
Thanks Frank for reminding of the mesh. I had to clean mine out thoroughly as well. I forgot to mention that to Tom.
Tom, a mud dobber is a wasp that gathers up mud any where he can find it to build their nest to lay their eggs in it. Beleive me they will find any hole they can to build in. I drill small nail size holes in my shovels and rakes to hang them with. If I don't hang them up and leave them standing open anywhere, they will plug it with mud and lay one egg in it. They are as labor intesive as ants are. I am an electrician and they will find my conduit on my truck and plug the ends of those to build their nest in.
Enough trivia and good luck. As F.I.T. says go slow and back your way into your research.
Dick
Elk Hunter
01-14-2006 18:21:00
Thanks guys, I'll give it a try tomorrow and let you know what happens. I am an optimist and I know this A is a runner it's just toyin with my patience right now. I gotta ask you though, what is a mud dobber? -Tom
F-I-T
01-14-2006 20:01:41
 Re: Clogged air intake in reply to Elk Hunter, 01-14-2006 18:21:00
Dick gave you a good explanation, but I'm surprised that you haven't ever seen their nest clobbed to side of a barn beam. Dick is right, they will plug up gas pipe vents, sewer vents (if the toilet doesn't flush right, check the vent for mud dabbers), etc.
Frank
Elk Hunter
01-15-2006 03:25:51
 Re: Clogged air intake in reply to F-I-T, 01-14-2006 20:01:41
Hey guys, I don't want to sound too back woodsish but here in eastern PA those things are around but not too often. I will check it out, thanks for the science class !!! -Tom
WV2cyl
01-15-2006 11:02:11
 Re: Clogged air intake in reply to Elk Hunter, 01-15-2006 03:25:51
I live in Eastern WV and have had major problems with those little bastards. I was working on a 320 engine,being very careful about the mud dobbers and ended up taking the oil pan and pump off twice before finding a nest in the oil filter housing. I bought a new 5400 and the second year we had problems with it shutting down and had to prime it and do all kinds of things to keep it running. The dealer wanted to replace parts but I kept working on it and finally found the hateful little devils had plugged the vent pipe shut. I told the dealer service manager what I had found and he was excited as it explained the problems he was having with other 5400s.
