Scotty, after two cylinders Im just not sure but can venture some guesses. Ifffff f the tractor uses a 6 volt coil with external voltage dropping (12 to 6) ballast, the ballast may be one of the ordinary looking white ceramic bathtub style (1/2 x 1/2 x 3),,,,, ,,,,, or a link of resistive wire,,,,, ,,,,or a link of a thermistor wire,,,,, ,and it has to be in series after the ignition switches IGN output and ahead of the coil somewhere??? Ifffff fff ????? ? it uses the 6 volt coil and a ballast PLUS has the ballast by pass when cranking system, what it does is apply full unballasted battery voltage to the coil ONLY WHILE CRANKING to by pass the ballast and put the full 12 volts (less cranking voltage drop) to the coil. In those type systems that will run ONLY while the starters being cranked but dies otherwise, its often cause THE BALLAST IS BAD OR TOTALLY OPEN or else the switch is bad or miswired. CHECK THE SWITCH WIRES??? There may be like an IGN terminal to feed the ballast and coil and another terminal to feed the coil ONLY while in the start position????? Likewise, if it will run ONLY IF HOT WIRED its either a bad ignition switch or an open ballast oropen ignition circuit wiring or shes wired incorrect or theres a short somewhere. Ifffff its a ballast system (resistor or resistive wire or thermistor) and if the points are good n closed and shes turned on, there should be around 6 volts on the coils high input terminal, but near zero volts on its low to distributor terminal. If the test lamp is placed over on the coils low output terminal and shes on and cranked over, the lamp should flash ON when points are open and OFF when points are closed. If it never flashes ON, the coil is bad/open or the points are shorted or never open or theres a short in the distributor n points wiring, or the condensors shorted. If it never flashes OFF, the points never close or are bad or theres a poor distributor ground. I still wonder about the switch wiring or a wiring short or an open ballast device. A test lamp ought to find the problem, however using the above. Got go run. let us know John T
