Forage harvester for model A
Rick in central
01-14-2006 08:46:17
Can a late model John Deere A run a forage harvester? What model did John Deere make for the model A and would anyone have any lititure on this forage harvester they could post?
Len Bull from NC
01-16-2006 09:07:42
 Re: Forage harvester for model A in reply to Rick in central MD, 01-14-2006 08:46:17
We pulled a one row New Holland forage harvester (PTO drive) with a 49 B in corn that averaged about 18 tons per acre, blowing into a truck, and it worked fine. Had a neighbor that pulled a JD chopper with an A and had even less trouble.
buickanddeere
01-16-2006 14:16:07
 Re: Forage harvester for model A in reply to Len Bull from NC, 01-16-2006 09:07:42
How short was the corn being cut? Was there a kernel processing screen in there?
Len from NC
01-16-2006 17:01:53
 Re: Forage harvester for model A in reply to buickanddeere, 01-16-2006 14:16:07
The corn was probably cut 3/8 to 1/2 inch theoretical..and you know that means there is some longer and some shorter. There was no kernal screen. We cut in early dent.
Mark Scholten
01-15-2006 18:02:35
I have a John Deere Model 62 (hay forager) / 74 (insilage chopper). I think those are the right numbers. Mine has the 4 cylinder Wisconsin engine on it. The B will pull it because it is only pulling it. Remember though, you have to have a wagon trailing also unless you want to discharge to the ground. I have an operators manual and a parts manual if you need any info. Email me direct.
Mark
billonthefarm
01-15-2006 06:21:15
rick In the old deere promotional movies it shows late A's pulling a modle 62 pto chopper. I dont know how well that would have worked. I have used a No. 12 chopper with a one row head on a 70d and a 730. These tractors run faster in first than your A but I usuually only chop some sweetcorn and it isnt a huge load but obviously these tractors are far more powerful than a late A. This is not even considering the lack of live pto. In todays modern hubrids with population over 30,000 I think chopping corn with a A would be impractical. Doesnt mean it cant be done. I have no information on the 62 chopper but I did watch one sell on time and passed on it and bought this #12 instead. Good luck!
buickanddeere
01-14-2006 14:38:09
A forage harvestor on a transmission driven pto tractor is rather optimistic. An A with it's low HP better be on a one row head and not be pulling the wagon behind. A 720/730 will handle a JD model (35 or 38 I forget which) with with a two row head if the knives are sharp and the ledger plate set correctly. A 70 with the fast 1st gear should stick with a one row head.
Glen in TX
01-14-2006 11:07:33
There was a 62 and 72 hay chopper made in the 50s and also a corn ensilage chopper. Think I may have some operators manuals on some. JD also made a ensilage chopper back then that used a 4 cyld. Continental gas engine for power.
I Bleed Green
01-14-2006 10:02:25
They first was the NO. 62 pick up type with hay or corn heads. The NO. 66 had a cutter bar. Next they made the NO. 8 and then NO. 6 and No. 12 They were of the flywheel type cutter head. I have the brochures for them. I can scan them for you, so send me a e-mail
David from Kansas
01-14-2006 09:37:33
Back in the 50's and 60's my uncle used his little AR JD on a one row harvester, I think it was a Model 6, and maybe later a model 8. Seemed to handle it OK. I remember when it started to pull down because of lack of power for the speed/amount of feed, he would pop the clutch, jerk it out of gear and instantly re-engage the clutch, so as not to plug the machine. What a great improvement live PTO has been.
