A won't start???
Elk Hunter
01-13-2006 17:06:24
Hey guys, This sounds too basic but I'm stumped! I got fire to the plugs, good gas flow to the carb I just carfully rebuilt and installed. When I try to start it won't go, just some smoke puffin out of the stack like it's burnin the fuel. Any suggestions? It's a 51" A. and it did this BEFORE I worked on the carb and ran ok a few weeks ago! Thanks Tom
fred from MO
01-14-2006 05:24:35
 Re: A won't start??? in reply to Elk Hunter, 01-13-2006 17:06:24
Maybe your coil is going bad?
Eugene SWIA
01-14-2006 04:44:00
Don't remember NGK #, but be carefull. NGK will take one size bigger socket and sometimes socket will wedge on the block. Never use Champions.I favor AC C87's. Gene
bob gray
01-14-2006 03:58:50
I have a 1945 A that acted about the same as described. Somehow I had reversed the plug wires from the mag. Put them back in proper order and she fired right up.
mbptractor
01-14-2006 02:52:07
I use Autolite 388 in all my 2cyl. Brian
DW
01-13-2006 19:39:58
I use AC c-87's in all my 2 cyls and get along well. This modern gasoline however, will get skunky pretty fast and then the plugs foul fast.
Maark
01-13-2006 17:30:08
Install new plugs..
Elk Hunter
01-13-2006 17:43:43
 Re: A won't start??? in reply to Maark, 01-13-2006 17:30:08
I guess I can do that, switch to autolites maybe. I am on my 3rd set of champions thinking I fouled them. What is the NGK equiv. to a Champinon D-21? My friendly NAPA guy couldn't tell me? -Tom
old
01-13-2006 20:14:09
 Re: A won't start??? in reply to Elk Hunter, 01-13-2006 17:43:43
Some times when you do something like that to an engine you have to pull it to get it to start. Then you can adjust things so they are correct. I had to do that with my B right after putting a new carb and mag on. Funny thing is that it started before it had been pulled 10 feet.
Island A
01-13-2006 17:56:44
I use Autolite 3116s with excellent results.
Dave
Elk Hunter
01-14-2006 08:10:21
 Re: A won't start??? in reply to Island A, 01-13-2006 17:56:44
I put fresh autolite 388's in and had my son pull me a little way. No avail. The coil is ok and a strong spark to the plug. When I pulled the carb to rebuild, I counted the turns on the idle needle and it was 2-3/4 turns off the seat. Does this seem too far. 1-1/2 turns is the starting point. Like I said it ran ok 2 weeks ago. Am I missing something else?
