4640 Fuel Tank Leak
superfarmer
01-13-2006 09:39:36
Got a 4640 with a leak in the bottom of the fuel tank, appears to be coming from two cracks. What"s the best solution? Should it be brazed or welded, put a tank liner in, or both? Thanks.
msb
01-13-2006 18:11:36
 Re: 4640 Fuel Tank Leak in reply to superfarmer, 01-13-2006 09:39:36
I have seen the short (first) fuel line rub a hole in itself.First thought it was the bottom of the tank too. That was on a 4430.
msb
01-13-2006 18:11:44
JDBert
01-13-2006 10:29:04
Our 4620 was leaking on the bottom, caused by the foam insulation holding dirt and moisture against the tank all the time. When we powerwashed it for painting it opened up LOTS of pin holes. We took the tank out drained it, flipped it upside down, ground and wirebrushed the tank bottom, warmed it up with a Knipco heater and applied a special 2part epoxy that they use in injection pump shops, that was 12 years ago and its not leaking yet. If you want more info my email is open.
G/MAN
01-13-2006 10:27:46
That's not an uncommon situation, particularly if the tank hasn't been kept drained and water builds up in the bottom. Our normal fix is to pump out the fuel, remove the tank, steam-clean it out very well, and weld the cracks or weld a patch over them, depending on where they are. Tap around lightly with a hammer on the bottom of the tank to look for other potential leak points. When you're done patching, plug off the holes on the bottom and fill it up with water to leak-check. New tanks are avaible from Deere, but the price will likely make your jaw hit the floor - $2300+.
