630 transmission done!
fixerupper
01-12-2006 20:14:09
Just finished putting the tranny back together in a 630 and boy was the bottom shaft ever a test of patience. By the time I got to the last spacer and the last gear the whole assembly was getting a little heavy and I was having trouble keeping the gear assembly pushed to the right tight enough to get the last spacer and gear in. Then there was the problem of keeping the left side bearing in the cone. I hadn't done this on a 630 for about 15 years and as usual the memory wasn't working too well so I didn't remember the mistakes I made on the last one until I made them on this one! I will probably be doing this again on another 630 within the next year and am wondering if any of you old timers who have done this many times have any tricks you would like to share. Or are there any? Thanks. Jim
Tyler-MO
01-16-2006 04:35:10
 Re: 630 transmission done! in reply to fixerupper, 01-12-2006 20:14:09
I"m no oldtimer at 22, but I"ve been taught by one. I just rebuilt the tranny in my uncles 630 in November of 2004 after trying to plow with a evergrowing noisy transmission. The trick with the bearings as told to my by my tractor mentor, Marvin Fluegge, is to not only pack the bearing in grease, but to cake the grease to it as it will most often stay put in the race long enough to get the shaft together. I put the gears/spacers on just like anyone would....one piece at a time. Good Luck,
Tyler in Missouri
