Disassembly of Wico X
Greg in MO
01-12-2006 10:37:58
I am in the process of tearing apart my Wico X to clean up and rebuild. I have it apart except for the rotor assembly, which looks like it is held in by the 4 "security" screws which theoretically you can't remove.
I want to put the case in the parts cleaner to remove all the gunk and old paint, but I would like to get the spindle out before I do this. Do I have to remove these screws to accomplish this? If so, how do I do this without destroying them?
Thanks!
Greg
Glen in TX
01-12-2006 10:59:02
 Re: Disassembly of Wico X in reply to Greg in MO, 01-12-2006 10:37:58
Greg, DON'T mess with those tamper proof screws on the housing laminations. The magnet rotor comes out the back, drive end. They put those screws on there so people wouldn't be getting the laminations out of line and messing the air gap up. The 4 screws on back side, drive end holding the impulse stop plate are what need to be removed to take the magnet rotor out. Take care and mark a line or not exactly which mark inside the housing the corresponding mark on stop plate is at for reassembly. You can also take the impulse nut off and take the impulse off before removing the 4 screws and magnet. No trick snap rings in the Wico XH so after screws are removed it should slide out or tap out with mallet.
Greg in MO
01-12-2006 11:02:31
 Re: Disassembly of Wico X in reply to Glen in TX, 01-12-2006 10:59:02
Glen,
Thanks for the info, I was guessing that was the case, but the rotor didn't want to just pull out, and I was hestent to start beating on it.
I will give her a tap or two and hopefull that will do the trick.
Greg
Mike M
01-12-2006 12:08:11
 Re: Disassembly of Wico X in reply to Greg in MO, 01-12-2006 11:02:31
This would be the ideal time to take the coupling off and pull the bearing holder off and clean and repack or replace that ball bearing. 50 + years can make that grease hard or all gone and that bearing could seize.
Glen in TX
01-12-2006 21:31:06
 Re: Disassembly of Wico X in reply to Mike M, 01-12-2006 12:08:11
Yes, It's just a standard 6201 shielded bearing or can use the one with rubber seals and not expensive to replace either.
Glen in TX
01-12-2006 11:10:16
Once the 4 slotted screws are out on drive end it should slide out but dirt and corrosion will sometimes make the magnet or ball bearing aluminum holder stick and it takes a light rap or two to get them out.
