JD 60 Hour Meter cable
Rusty96
01-12-2006 09:54:24
i have a 1955 JD60 and have recently bought an hour meter for it. apparaently the part number is # AA5745R. I am looking for a cable to match. can anyone tell me what the part number for the cable is that should match the meter?
Thanks.
little h
01-13-2006 17:18:09
 Re: JD 60 Hour Meter cable in reply to Rusty96, 01-12-2006 09:54:24
frank is half right. the new cable is $55 from deere but if you have the outside housing you can order part AB 4776 that is the inner cable. I just bought one 3 weeks ago from the dealer for my 60 for $26. the dealer even had to get it shipped from Moline so it is still a current part.
Rusty96
01-15-2006 21:49:22
 Re: JD 60 Hour Meter cable in reply to little h, 01-13-2006 17:18:09
Thanks guys. i will need the complete cable. so if it is not what frank first suggested as AB 4737R and is not the inner cable AB 4776 then which part is it? i'll try to search on that JDparts site but if anyone has it handy then please post it.
thank you.
Rusty96
01-15-2006 22:06:48
 Re: JD 60 Hour Meter cable in reply to Rusty96, 01-15-2006 21:49:22
i struck out on the JDparts site. i must be doing something wrong because i only get a few parts for the 60. sorry guys but if it isn't too much trouble please post the part number.
thanks in advance.
F-I-T
01-13-2006 20:00:12
You are correct! I must have mis-typed it when I checked it on jDParts.com, because it certainly shows up now.
Wes Storm
01-13-2006 16:25:50
Metro Speedometer in Independance Mo. They rebuilt my tac for a 1957 420 T JD, Then made me a complete inter/ outer cable just like the orgional for $22.00, Deere wanted $63.00 for a new style. 816 478 0116
Jim Dunn
01-13-2006 01:57:08
If you have the old cable, you might take it to a shop that rebuilds starters and generators and find that they could have the parts to make you one. I recently restored my 520 and needed to replace the cable. I mentioned it in that shop and they fixed me right up with everything from the tach on back to inside the gov. houshing. Square shaft and all. Good luck.
Jim
F-I-T
01-12-2006 10:27:59
I get a number of AB 4737R. Deere shows them as available for about $55.00. Long ago you could buy just the inner shaft, but now you have to bu the whole assembly.
Frank
