3020 hydraulic pump
jeff-pa
01-12-2006 09:17:21
My pump is leaking more than usual around the shaft seal. I think I understand that the tube back to the trans is to drain some of the known leakage. Is the tube designed to gravity drain back to the trans? the point at which the tube leaves the pump is about 24 inches from the ground and where it enters the trans is 32 inches. why would that work if it is not pressurized?
I have made sure the tube is clear.
As always, thanks for any input.
G/MAN
01-12-2006 10:53:03
 Re: 3020 hydraulic pump in reply to jeff-pa, 01-12-2006 09:17:21
The outer seal that you see is not designed to seal much pressure, and is a simple lip-type seal. Most of the pump sealing is done by the quad-ring seal located further into the pump. If the quad-ring has failed due to age or an internal problem in the pump - such as excessive "crankcase" pressure in the pump becaue of oil getting by the pistons or a cracked housing - too much oil gets by the inner seal, and the bleed line can't let it go back to the tranny fast enough. Then the outer seal will start leaking. The bleed line drains the area between the two seals, similar to a water pump weep hole. The bleed oil is pressurized, but not a great degree, which allows it to flow back to the tranny housing and back into the reservoir. If your problem is a kinked or plugged bleed line, replacing the line and the outer seal might fix it. If the inner seal is leaking, replacing the outer seal is nothing but a band-aid, which probably won't last long. The outer seal can usually be replaced with the pump still in the tractor. Replacing the inner seal requires pump removal and disassembly.
jeff-pa
01-16-2006 09:19:44
 Re: 3020 hydraulic pump in reply to G/MAN, 01-12-2006 10:53:03
Thanks for the info. The rest of the story is that my FEL has gotten REAL slow and shaky but still builds up pressure.
My next move is to do some tests to get a feel for the health of the pump. I was going to get a guage to check the pressure at the remotes.
