Bench checking a fuel pump .
Dan C.
01-12-2006 05:28:19
I had posted some time back about my 1830 tractor having fuel in the oil pan. Thanks to some advice from here (and others) I am looking at 2 places this could come from - fuel pump or injection pump.
I have the fuel pump off and wanted to check it on the bench to see if fuel is leaking out the back. I have a pretty good idea on how to test it but wanted to see how some of you have done this as well ? ?
If my fuel pump checks out OK then I might be asking questions about taking off precedures for a injection pump.
Thanks in advance for any help and ideas - yall have been very helpful.
Dan
Roy Suomi
01-12-2006 20:23:26
 Re: Bench checking a fuel pump . in reply to Dan C., 01-12-2006 05:28:19
You can bench test these pumps by hooking it up to a fuel source with the suction side. On the output side hook up a line with an oriface or restricter in the line . This restricter will make the pump pressurize the fuel . Most pumps have an actuater arm on the side of the pump. If not actuate the arm that contacts the camshaft. Extreme caution not to spray yourself with pressurized fuel . Another test is to install a vacuum guage to the suction and actuate the pump to see if the guage goes up and stays up a reasonable length of time..
Dan C.
01-13-2006 06:54:47
 Re: Bench checking a fuel pump . in reply to Roy Suomi, 01-12-2006 20:23:26
Thanks for the reply and information.
I did find that the pump was leaking fuel out of the back - where the mech lift arm is.
How I checked it was I have access to a calibrated adjustable air supply. So I applied air to the suction side and plugged the discharge side. I had the fuel pump in a vice with the mech.
lift air sticking upward. I then filled that area with leak detect (soapy water works well). Then applied 10 psi to the suction side - it was leaking out the back - blowing buddles. It was even leaking with 1.5 psi.
I hope this is the source of my fuel leak into my oil. ORdered a rebuild kit for the fuel pump ($30)
and going to install and see if fuel will be present in the bottom of the oil pan. If fuel is
still pooling up then its on the injector pump.
