rivets
bigreddm
01-11-2006 14:26:06
Although this is not a John deere question, maybe someone here can help me. I have a pressed steel rim on a JD B. the rim is rusted out. I bought another wheel. the one I bought has somewhat a bad center. I ground the rivets off and want to put my old center(better shape) to the newer(less rusted) rim. I"m haveing a hard time finding the rivets. the holes the rivets go in are a little big for a 3/8" drill bit but to small for the 7/16" bit. I already called JD, and tractor supply with no luck. Any help????
msb
01-11-2006 19:57:07
 Re: rivets in reply to bigreddm, 01-11-2006 14:26:06
www.millertire.com.
They can supply you with rivets.I suspect you will have to ream the holes out to 7/16" as the riveting process has closed the holes a bit.I did.Just finished a MH 9x38 wheel.Cut the rivets to length first.Used a piece of 3/4" pipe cut to length and used a 3/4" bolt and nut in the end of the pipe to jack the rivet into place and give the rivet some support before heating the rivet and peening it into place in the wheel.Ground a divot in the bolt head to keep it from slipping off the rivet head.Used a larger bit to countersink the rivet hole before peening the rivet.Then ground the rivet down smooth.
bigreddm
01-11-2006 15:36:54
thanks....
RalphinWI
01-11-2006 14:51:00
This is a pure unadultered quess, but I would suspect they used 3/8 rivits, putting them in hot(!) and used an air hammer to tighten them. As the rivit is hammered, it will shorten and expand circumferentialy to seal air tight, as well as form a rounded head.
Bob
01-11-2006 14:42:02
Try McMaster.com.
Bob
01-11-2006 14:51:16
 Re: rivets in reply to Bob, 01-11-2006 14:42:02
third party image
P.S....
The Deere parts guy could have helped you, if he was willing to do a little research. Deere has their hardware and other parts items cross-indexed by specs, and he could have looked, based on dimension.
What kind of head on the rivets... likely "countersunk" style, like this illustration?
How long? The Deere part # for a 3/8" diameter X 1" long flathead countersunk rivet is 16H1327, @ about $.19 each.
If you need a different style head, or another length, post back, and I'll take a look for you.
