Huh?
steve from mo -
01-11-2006 08:07:51
Questions?
How do you know the guage is good?
How about the sender?
How about the wiring?
One possibility is that the thermostat is stuck open, but if you are working it that engine should run warm in the summer without a thermostat. Another possibility is crud between the circulating water in the engine and the water that the sending unit is sampling.
RFox
01-11-2006 08:22:16
 Re: Huh? in reply to steve from mo - dangit!, 01-11-2006 08:07:51
Good questions, I know the guage is good, because it is the old fashioned kind - with just the copper sender that goes into a pipe that comes off the manifold, and it used to work fine. I suppose it is possible that it broke, but on the surfact it looks like its still fine, I guess I should start there though. You've got a good point about the 'crud' - I'll check that at the same time. I appreciate your help!
WTW
01-11-2006 13:11:40
 Re: Huh? in reply to RFox, 01-11-2006 08:22:16
I think you just gave the answer to your question. You said sender went into pipe?? The sender has to be in the head water jacket where it was designed to take its sample from. If someone has added a pipe fitting for heater reasons and relocated sender bulb up out of water jacket it never will work correctly or maybe not even at all, if it did it would take much more running time for engine to get extended water pipe fitting warmed up enough to even register a half a$$ reading. Get the sender bulb back down in head water jacket where it supposed to be and you will find it will work like it was designed to. Good Luck, DW
RFox
01-12-2006 13:09:42
 Re: in reply to WTW, 01-11-2006 13:11:40
Thanks WTW!!
G/MAN
01-11-2006 10:22:15
The gauge is likely junk, as the capillary tube is filled with ether, which expands as the temperature goes up and drives the needle up. A kink or pinhole can let out the ether and you have no more gauge function. Mechanical gauges can fail just as easily as electrical ones, and more easily if care isn't taken with them while splitting the tractor or making other repairs.
Matt_In
01-11-2006 08:32:00
I had a brand new temp gauge right out of the box not work. Like all things they do break.
