Front bracket off JD 40T
Dean K
01-11-2006 07:14:08
I have a part which has been laying around the shop for years. I restored a JD40T for my brother, (now deceased) Sold the tractor but have this bracket. (May also fit MT, 420 and 430) It bolts to the two front-end lugs, is shaped like an "H", with a 1.375" hole on each side and two 11/16" sq. holes on each side for 5/8" RH bolt.
I'm guessing it may be a front cultivator mount. Any hints? And, if so, a guess as to what model?
Thanks
Jason Mills
01-11-2006 07:40:56
 Re: Front bracket off JD 40T in reply to Dean K, 01-11-2006 07:14:08
It is the front mounting bracket for the cultivators, or the front weights when the cultivators are not in use and dismounted from the tractor. I purchased my grandfathers tractor (a 1955 40T) that he purchased new and was delivered on May 24, 1955 after his passing two years ago. I have the full cultivator set and the front weights that mount to this bracket you have described. This bracket should mount to the bottom right behind the pedestal.
