4555 Oil Pressure Warning
Patrick King
01-11-2006 06:37:48
I have a 4555 with 4000 hours and recently the stop alarm for engine oil pressure stop light has been coming on after start up and intermittently there after. I have temporarily attached a mechanical gauge and always have in excess of 40 psi oil pressure during each of these warning events. I have the service manual and have done some tests but thought I would post before I ventured any further in vain. Any thoughts or help appreciated.
Patrick
G/MAN
01-11-2006 07:31:20
 Re: 4555 Oil Pressure Warning in reply to Patrick King, 01-11-2006 06:37:48
billyiron is correct - more than likely it's the sender unit, but also give the wiring harness running to the sender a look. The black plastic split-loom wiring cover on those tractors tends to get pretty brittle with age and heat, and will start falling off. Check and make sure the wiring isn't rubbing against the rear hood support, etc and causing an intermittent short to ground, which will turn on the light. The sender is actually just an on/off switch, calibrated to close and turn the light on when the oil pressure drops below a certain level.
billyiron
01-11-2006 07:24:33
Id guess sender unit,, I bet G-Man will see this he'll know for sure how to help you,,,billy
