? for Mr. Larson
Van robinson
01-10-2006 21:36:39
I read your response to P Browning about the mag timing.Matter of fact, you emailed me about the differences in setting the start timing and run timing. But I have another question. The timing on my '40 B was so bad off that I had to raise the gov. and turn it a bit and set it back down to be able to get it close. I was able to get it between 25 and 30 degrees BTDC on the run timing. But I can not get the start impulse to trip at TDC due to running out of adjustment on the impulse trip arm. As it is now, it trips at about 5 degrees after TDC. The mag is rotated as far toward the front of the tractor as possible to get the correct run timing. If I raise the gov. and turn it one more tooth, will I still have enough adjustment on the run timing to get it to 25 degrees BTDC and be able to get the start timing in too? Sorry for the long post.
buckeye al
01-11-2006 14:32:11
 Re: ? for Mr. Larson in reply to Van robinson, 01-10-2006 21:36:39
I have worked on several mags where someone had dropped a screw while replacing points. The screw fell into the mag & the magnet picked it up. The screw was never found and became lodged between a magnet shoulder & the end of a pole piece. The very hard steel of the coupling's drive plate being keyed to the shaft by only a flat on the shaft then twists on the shaft out of position with the flat. That's for the lucky feller. For the unlucky, though rare it twists off the shaft. With the wiped out flat, run timing becomes a difficult thing to accurately set. Impulse trip will still be OK though spark may be weak. Run may be way late or the run timing may even be different each time it started and checked if the drive coupling is not tightly installed.
I've had the same problems you describe & wanted you to know what I have found more than once. Maybe you have the same trouble, maybe not.
With a 1/16th rod & just a quick dab of arc weld then some filing I've been lucky enough to be able to repair all of them I've encountered so far.
Duane will get you on the right track.
Good luck.
Duane Larson
01-11-2006 05:50:32
Van,
Well, it sounds like something is wrong somewhere. As Mike says, check the number on your drive cup and let us know. It will often have a part number cast in, or the degrees of advance, but some have no info.
As I noted in my response, wear on the impulse plate, magnetic rotor shaft, and drive cup can accumulate and cause the problem you are observing. Also, cumulative wear in your gear system leading to the governor drive can also have an effect - in particular, when the piston is at TDC the slot in the governor drive shaft for the magneto is not horizontal. You can try moving the governor shaft another tooth and find out if you can achieve both correct run and start timing.
Wear on the magneto cam where the point rubbing block rides can also affect the timing of the spark (as well as it's intensity).
If that doesn't work, I guess I would take the impulse unit apart and look for wear, and check the cam/point rubbing block for wear. That is why I set the points so the edge gap is correct - which may lead to a point gap different than called for.
Mike M
01-11-2006 05:11:03
Which impulse coupling is on your mag. ? A 25* or 30* or 35* it should have a number stamped right on the impulse coupling. Also where do you have the index marks set at on the back of the mag. ?
