D IN PIECES
jasonc36d
01-10-2006 21:13:24
I HAVE AQUIRED A 1936 D IN PIECES IT IS ALL THERE JUST IN MULTIPLE LARGE PIECES.IT IS NOW ON RUBBER BUT I BELIEVE IT ORIGINALLY WAS ON STEEL WHERE DO I BEGIN, SO I CAN END UP WITH A FIRST RATE RESTORATION
JC36D
01-11-2006 21:11:45
 Re: D IN PIECES in reply to jasonc36d, 01-10-2006 21:13:24
THANKYOU FOR THE INFORMATION I WILL TRY TO POST OUR PROGRESS AND I AM SURE ME AND MY 8 YEAR OLD SON WILL HAVE A LOT OF QUESTIONS FOR YOU GUYS
Glen in TX
01-10-2006 22:32:56
Like Jim said some manuals will answer lots of questions for you and are still available from JD or online vendors. PC658 parts catalog covers the unstyled Ds 23-38. Good service info and operation instructions in the Dir.225 covering the 31-38 D. More service info in a I&T JD-4 shop manual and it mostly covers the styled D but that is the same engine and trans as in your 36. Many styled D parts will work on your 36. I believe the change from 6 spline axles to 12 spline was made sometime in 36. If your 36 has the 12 spline axles and cast centers with rims for tires it probably came that way. If it has rims welded on spoked centers probably came on steel. Then there were aftermarket F&H spoked rims also. I've had several D serial numbers researched and they won't usually tell you anything about wheels but might. Hopefully the other owner gave you indication of why it was in pieces also so you have a starting point on what more to look for before going back together with it.
CalJim
01-10-2006 21:44:23
First get yourself the best parts/service
manuals you can find. There are also several
decent books out there if you are just
getting started.Since you are in pieces a
parts inventory would help. That way if you
are missing some things you can start looking
now.The Two-Cylinder Club can research your
tag to see if it originally came on steel.
Most important that you use this forum for
your questions,alot of knowledge here.
HAVE FUN AND BE PATIENT!
