1969 John Deere 2020
Troy Hanes
01-10-2006 20:02:39
I have just purchased a 1969 John Deere 2020 utility tractor and it does not have a loader or any brackets to mount a loader can someone please help me with this problem
Matt in PA
01-11-2006 08:36:00
 Re: 1969 John Deere 2020 in reply to Troy Hanes, 01-10-2006 20:02:39
Troy,
I take it that you want to add a loader to this tractor. The brackets that you speak of are most often specific to the loader. I would recommend purchasing from mother Deere the side plates that connect the trans to the front end of the tractor. I am assumming that yours does not have these. These plates bolt up just in front of the clutch and brake pedals and bolt to the front end just before the engine block. These tractors used the engine block as part of the frame. I have a 2020 w/ a # 48 JD loader on it. It is a great loader tractor. If money is not an issue look into a new JD loader. I have a 541 loader in my 2150 and I can take it on and off in less than 5 minutes. I can also switch buckets very easily.
My 2 cents,
Matt
