720D RUNDOFF
Greg H. WV
01-10-2006 11:23:11
I had a hair raising experience one evening last week. I was getting ready to pull into my drive way on my 1958 720 diesel, and when I pulled back on the throttle lever, the moter took off, and started running away from with itself. I yanked the clutch slammed on the brakes, and pulled the decompression lever. That did stop the tractor after a few seconds, but I gotta tell you the thing nearly doubled in RPM, before I got it shut down. In checking the the linkages, they all appear to be intact,with the throttle linkage attached to the rod, going into the govenor housing. I have an IT manual, borrowed from a friend, and a parts book. I'm getting ready to tear into this thing, for what I'm guesing is a problem in the govenor, but you have to understand, if I were to go to "mechanics school", I'd be riding the short bus, with the teacher aid. So I'm asking what to expect to look for in regards to irregularities in the govenor on a 720 Diesel? And could there be anyother causes to the engine running away with itself besides the Gov. ? Thanks for any help in advance. Greg H.
Carl NY
01-10-2006 15:18:29
 Re: 720D RUNDOFF in reply to Greg H. WV, 01-10-2006 11:23:11
Greg. I agree with F.I.T. Sounds like a gov. weight fell off the hanger. I had a 730 diesel that did the same thing. Last I knew JD had weights left in stock. If not e-mail me.
buckeye al
01-10-2006 14:58:56
I assume you killed it with the decompression lever because STOP did not work.
If stop did not work I lean towards a linkage problem more than a weight problem.
The spring to the right of the rack will push the pumps to full fuel delivery if the governor looses control. The STOP function pushes the pump rack to the right (compressing that spring) setting the pumps to a no fuel delivery position and the engine coasts to a stop.
If the linkages were all still functional then pulling the throttle lever back to STOP should still have shut it down even if both weights flew off! That's why I'm thinking linkage failure some place. Could be broken linkage, broken pivot in the governor lever housing, messed up linkages in or to the governor or possibly broken rack to left of the #1 pump.
If I recall there's a slotted fork like pivot on the rear end of the lever in the governor lever housing that feels or follows another lever inside the governor. If the side of that fork broke (or wore) off or lost "its grip" in the governor, it's likely to run away and STOP won't work.
Good luck and post back with what you find.
Greg H. WV
01-11-2006 07:00:11
 Re: 720D RUNDOFF in reply to buckeye al, 01-10-2006 14:58:56
Al,
to be honest with you this whole incident happened so fast, and the fact that I had the trottle back against the stop, I didn't even think about pulling the stop, because I just assumed I had a loose linkage, so that is why I decompressed, for the shut down. Man I was so afraid that thing was gonna blow up. We've had a death in our community, so I won't get to get into the govenor, until this week end, but I'll post back if I get stumped. Thanks for yours and everyones input. Greg H.
buckeye al
01-11-2006 14:37:49
 Re: 720D RUNDOFF in reply to Greg H. WV, 01-11-2006 07:00:11
Understand that situation very well sir! At times like that, whatever works is what counts and taking the wind out of his sails will work every time! That's why GM had an air shut off at the blower housings.
Hope you trouble is something simple & easy.
Good luck.
billonthefarm
01-10-2006 14:41:35
greg Take a look at those gov weights. Had one come off once. I was thinking I was able to just pull the throttle back and shut it off. If you had to kill it maybe you will have something else wrong. If it isnt a gov weight problem you will be in the right place to start looking for the problem anyway. Good luck.
B-maniac
01-10-2006 13:35:35
I'm not real familiar with a 720 injection pump but have rebuilt many 4 / 6 cyl. pumps for JDs and they too have a centrifugal governor controling fuel volumn. Just another avenue you might persue,if something came loose or jammed it might do the same thing as you are describing.
Mike M
01-10-2006 12:22:38
I'd also say thrown gov. weight. Were you going down any hills and overspeeding before this ? Wear can cause the weight to pop out of place too.
The 720 I heard do this really sounded good and smooth at those high RPM's. That suprised me somehow I thought it would really vibrate or be rough or blow up or something.
ebbsspeed
01-10-2006 11:42:44
Typical runaway in a diesel is caused by an increased source of fuel. Oil from an overfilled air cleaner perhaps spilled when you made the turn into your drive, or some seal bad which causes oil to be pulled into the intake tract. This happens occasionally on big rigs where a turbo seal fails catastrophically and allows the engine oil to be pulled into the intake.
F-I-T
01-10-2006 11:41:46
Greg:
I don't have much time right now and gotta run, but it sure sounds a lot like a thrown governor weight.
Frank
