820 tach/hour meter
gpwtboy
01-10-2006 10:31:11
the tach cable connection at the engine block on the underside keeps leaking oil, all fittings are tight, leaks oil with engine running and also if tractor sits for A long time , got any reason why or what causes it to leak, do i need a new cable, or what!!!!!, pain in the neck oil leak, thanks, GPWTBOY
Mike M
01-10-2006 12:25:28
 Re: 820 tach/hour meter in reply to gpwtboy, 01-10-2006 10:31:11
JD has a part number and used to sell and may still sell a rubber seal that will fit in there. Maybe that's all it needs ? I'll have to see if I can find the number.
gpwtboy
01-10-2006 15:27:37
 Re: 820 tach/hour meter in reply to Mike M, 01-10-2006 12:25:28
you got it, got to be something to stop the oil from leaking, you know I should get off my butt and get a parts and service manual for a 820 blackdash , thanks GPWTBOY.
Mike M
01-10-2006 17:35:35
 Re: 820 tach/hour meter in reply to gpwtboy, 01-10-2006 15:27:37
I didn't look in the parts book so I really don't know if they call for one in that application,but I would put one in and try it.
Mike M
01-10-2006 13:54:32
part number B3285R
