For Duane Larsen -- Running Timing
P Browning
01-10-2006 06:18:20
You mentioned in an earlier YT posting that you like to set running timing in the 25-30 degree BTDC range when operating on gasoline. Would this value be right for aviation gasoline as well? Would it be better toward the 25 degree mark?
Also stated was that unstyled JD engines seem to start easier if impulse timing is 3 - 4 degrees BTDC. Do you literally mean "unstyled"? I've owned and operated (actually farmed with) both styled and unstyled JD "A" tractors, for instance, and the difference in behavior of a '41 "A" and a '36 or '37 "A" isn't much.
I guess, bottom line, the question is. "Would advancing the start timing help on a mid-40's JD tractor; or any all-fuel JD tractor with magneto ignition (before duplex carburetors)?" I guess it is the "unstyled" descriptor that has me baffled. Perhaps there is some other more appropriate differentiating characteristic that I am over-looking here. (PatB)
Duane Larson
01-10-2006 19:05:27
 Re: For Duane Larsen -- Running Timing in reply to P Browning, 01-10-2006 06:18:20
Pat,
I'll provide my responses to your questions - lots of good info from others, much of which I agree with.
First, I have never used airplane fuel so I can't comment from experience. It has higher octane, around 100 I think, which slows the ignition flash so I suppose retarding the timing to 35 or so would be fine.
My comments about a small amount of advance (3-4 deg) results from some years of fooling around with hand start Deere's. The styled, electric start Deere's aren't to demanding about starting ease - just grind the starter a bit longer. But if you are trying to hand-start a Deere with a larger engine, it is very helpful if everything is tuned well to minimize starting effort. In that context I have observed that a small amount of advance seems to make my tractors start with less revolutions. I don't have a theory to back up my experience, but discussions with others who have hand start Deeres generally confirm my experience. However, I readily acknowledge that hand-starting a Deere is rather closely tied to the tractor in terms of choke setting, throttle setting, etc. and timing is likely also part of the proper formula.
So, I guess I should have said "hand start" rather than "unstyled" to be more consistent with my experience. I only have one electric start Deere - a '51 G - which is a working tractor with a DR distributor.
I would not make a flat statement that 3-4 degrees of advance will make your tractor start easier - but it seems to help mine and I set them up that way.
I agree, and earlier posts of mine have pointed out, that the problem of wear of the impulse plate on the magnetic rotor shaft and resulting changes in running timing can be important. The best way to understand the effect is by spinning the magneto on a test bench to observe timing relationships for a given magneto. Wear occurs at the impulse plate, and at the drive cup-impulse plate interface. It can be an important cumulative effect.
As I have pointed out in past postings of running timing , the maximum voltage spark occurs when the magnetic rotor is past the pole piece by the edge-gap distance. This rotor position is directly related to the drive cup through the impulse plate. The engine demands a spark at a particular position of the governor shaft which spins the drive cup. So, if the engine design is for a spark occuring at 25 deg before top dead center, a 25 deg drive cup must be used (but as noted earlier, wear can affect this and give a different number of degrees advance). By rotating the magneto on the governor box (for a flange mount magneto) some adjustment of the magneto timing relative to the engine timing is obtained.
This is already way tooooo long a post so I will stop. Sorry.
P Browning
01-10-2006 20:43:18
 Re: For Duane Larsen -- Running Timing in reply to Duane Larson, 01-10-2006 19:05:27
Thank you Duane for giving me your time. For the average Joe out there, the only test stand he will have is his tractor, and usually very little by way of back up spare parts to toy with. And so for such a fellow, more often than not, one with no experience with the "backside" of a magneto, he will do quite well to leave analysis such as lag angle ala running timing advance up to one having a test bench; especially if his experience is a one-time deal. Thanks again. (PatB)
B-maniac
01-10-2006 13:47:23
Not a reason in the world to run advance for starting,especially on a long stroke engine. Even a couple of degrees atdc wouldnt hurt.
John T
01-10-2006 07:03:00
Hi Pat, good questions for Duane, Im anxious to hear his comments. As far as the initial start timing, I HATE IT when my hand crankers kick back cuz of too much advance BTDC timing n spin the flywheel backwards and/or burn my finger tips cuz of the "death grip" I had on it. Therefore, I guess I set mine closer to dead TDC but Im hesitant to set them much more if any advanced to avoid kick back. Id like to hear how or why either of you and anyone else like them set BTDC for starting, although, I guess so long as its not to much to cause kickback it might start better?? Even if she were an electric start, that kickback may be hard on starter drives it seems.
Where do you and others set yours to start???
John T
Earl-IL
01-10-2006 08:10:59
 Re: For Duane Larsen -- Running Timing in reply to John T, 01-10-2006 07:03:00
John, I do a lot of mag. repair. I have noticed the normal wear in the impulse coupling has effect on the running timing due to fact that say you have a 25 deg. coupler. When running on the mag machine checking the advance the wear in the coupler may make it 27deg or 28 deg. So I always recommend the running timing on a parade tractor set at 20-22deg. and a gasoline plow tractor no more than 25 deg.by degreeing the flywheel. Earl In Illinois
Mike M
01-10-2006 08:50:02
 Re: For Duane Larsen -- Running Timing in reply to Earl-IL, 01-10-2006 08:10:59
Didn't the later ones have a 35* impulse coupling ?
Glen in TX
01-10-2006 13:28:22
 Re: For Duane Larsen -- Running Timing in reply to Mike M, 01-10-2006 08:50:02
Nope, The earlier ones for all-fuel used a 35 or 30 degree drive cup and lag angle setting for the mag. When gasoline and high compression pistons became more common and electric start the switch to 25 degrees was made on the mags. Even a special 25 degree long lug drive cup was made for the Wico XH mag for model D using high compression gas pistons. I agree with Earl about the impulse parts wear being the reason for having to set the timing back some on the mag impulse stop ring. You still want to time the mag to engine as closer to TDC to prevent kick back though.
