B carburator
wayne counts
01-10-2006 05:08:23
I have a #34 on a 1942-1943 B could I replace with a #10 off of a 1939B? Thanks for any help
G2 DEERE
01-11-2006 04:48:33
 Re: B carburator in reply to wayne counts, 01-10-2006 05:08:23
I HAVE A DLTX 10 ON MY 41 B AND IT WORKS FINE STARTS GOOD BUT I JUST PLAY WITH IT YOO.
Duane Larson
01-10-2006 05:49:40
wayne,
While it will bolt up, it has a smaller bore sized for the smaller engine used in the B until 96000, at which time they increased the bore in both the carburetor and tractor.
If you use your tractor mostly for parades, etc., it probably will work ok.
Jason Z in MO
01-10-2006 11:31:23
 Re: B carburator in reply to Duane Larson, 01-10-2006 05:49:40
Duane,
I was under the impression they increased the bore in 1939 with SN 60,000; same time it was styled. The bore was increased to 4.5" with a displacement of 175 cu. inches. At SN 200999 it bumped again.
The carb did change at SN 96,000 from DLTX-10 to the DLTX-34. Was this when the head changed and the "eye brow" was cast around the intake valve? Or was the DLTX-10 really undersized at SN 60,000 and corrected at SN 96,000?
I just double checked the parts book. Assuming an all-fuel, the rings are the same from 60,000 to 200,999.
Duane Larson
01-11-2006 08:50:14
 Re: B carburator in reply to Jason Z in MO, 01-10-2006 11:31:23
Jason,
Oops - you are correct, the bore was increased at 60000, not 96000. JD advertising introducing the "new, more powerful" tractors for 1941 corresponded to the change from 10 to 34, for the reasons you noted.
Thanks for keeping me honest.
wayne counts
01-10-2006 06:31:41
Thanks alot for the help we will just putter around so it should work fine thanks again.
